Speakers Worthy of Pass Amps?
Mico64, I'd forgotten about that review. It has some interesting observations in it. Also, it was interesting to note Mr. Reichert's conclusion, "... many audiophiles fail to realize that sensitivity ratings are rarely a wise guide when matching power amps to loudspeakers."
I've been preoccupied with an unexpected plumbing project since posing the questions in the original post. Living in a 50+ year old house has its surprises from time to time. I'm now impressed by all of your replies especially the variety and creativity of the number of responses so far! :)
You might want to read also First Watt J2 power amplifier | Stereophile.com
It is a nice review of J2 but also provides you some views of speakers which worked :p and the ones which worked less :mad:.
I like the J2 very much...:D
Need 10x power for the same sound level with 85dB speakers if compare to 95dB one's. Use 10 watt amp or 100 watts ?
Distorion go higer level if power incrase and without talk about colorations components brings.
I appreciate highly educative Papa article speak at CAS :
http://www.firstwatt.com/pdf/art_cas_2015.pdf
Thanks Mr Pass and all Diyers so nice !
I use Transformer Volume Control preamp recently and transform music like buy better pair of new speakers :)
Speakers crossovers and match with amplifier damping factor make difference no doubt. I like non crossovers at all :)
Not worthy...
I have a 5.1 horn loaded home theater all class a, with Klipsch Jubilees in Walnut, K402 MEH center and all three with TAD 4002 beryllium drivers. Rear speakers are 1978 Klipsch Belles in Rosewood. I run Aleph J, VFET, SIT 2, and a crown to power the Tuba THT horn loaded sub that I am sitting on in the photo.
Sounds better than any movie theater I've been to. Paint, carpet and new recliners for Xmas...
Thank you for your interest. :D
I found a picture taken last summer.
@ Plasnu
Interesting audio system congratulations.
If you have today 3 tables like show on your photo do you ready try how they sound if you put all turntable, Aleph, preamp , DAC on the center. Use left and right tables to jump up speaker cabinets on them with in the corners 4 fat books underside for softer wood & wood contacts. It's work for me woofers response give me fuller bass if placed in higher position ,
more distance from the floor.
Greetings :)
WOW! I'd settle for just the Jubilees! Very nice 5.1 set up...
