Hi
I am a completely newbie so this might be a really dumb question but anywho... I upgraded a pair of nuforce amplifiers recently that left me with 2 unused ampboards that I thought I could use to build a descent stereo-amp with if possible! So my question is can I use a psu from another manufacturer (like hypex) or do I need to stick to the psu made originally for that ampboard? Is there any particulars that I need to check to see if they are compliant or is it:"just forget about it!".
These ampboards are load invariant (dunno if that makes a difference)
/Johan
/Johan
Any manufacturer's PSU should be fine as long as it meets the required specs. Do you have the model number of the amp boards and are the specs available?
Thanks a mill for taking the time🙂, They are Nuforce ref 9 V2 SE amp boards: I found these specs in a review of them from here :
Power/Load 8 ohm 4 ohm 2 ohm
Peak Power (20 msec hold time)
RMS Power 190W 300W 300W
Power bandwidth: 100 to 20 kHz +/- 0.8 db 10 Hz -0.5 db 60 kHz -3 db
THD+N = 0.03%, 1kHz, 10W
Input impedance: 45K ohm
Gain: 27 db
SNR = 100 db at 100W
I have been looking at the Hypex smps 600 (delivers 600 W) or a Hypex SMPS1200A700 and thinking of a single PSU for both ampboards. From what I have read the Hypex kits have got great reviews so I am thinking their PSUs might be a great choice as well or are there "smarter" solutions?
Regard
/Johan
Gain: 27 db
Regard
/Johan
Does the switching frequency in the psu matter?
It seems that the original nuforce psu has a higher switching frequency ( 500 kHz) from what I have read and the hypex PSU's (100 kHz)
I believe they are 48V! ( according to an interview with the founder and this ad for V2 boards
/Johan
/Johan
So that rules out smps600 leaving smps1200A180 as option, the a700 version is +/-85V. But better be certain what you need, just +/-48V or maybe different voltages too for other parts of ampboard ????
Thank you so much!
Is there any specifics that I should look for on the board itself like any other Voltage connections.
There is a lack of info about these amp boards online and there is no support for diy-projects from nuprime (former nuforce) so I will have to draw conclusions from taking a look the board itself!
In the upgrade manual however ( instructions for switching the amp boards) they are talking about a 5V and a 52V ground. Can I draw any conclussions from that.
/Johan
/Johan
Hmmm I might be wrong about the operating voltage, it seems to be 52V, the 48V was for small stock that had problems with overheating due to the dc/dc converter.
If you still have the original power supply, maybe we could help you measure the voltages if you have a multimeter and can post a hi res image of the PSU.
I took some photos of the psu board and there are 6 'connectors' on the bottom of the board that are marked :
* +5V
* GND
* GND
* GND
* 48V
* 48V
Here is a picture of the psu board itself
And here is closer look of the 'connectors' on the psu board
So what conclusions can I draw from this, is it 48V or is 48+5=53V or do I need to measure it?
/Johan
* +5V
* GND
* GND
* GND
* 48V
* 48V
/Johan
Looks like a 48v and 5v single rail made by Skynet. Is there a model number near where it says Skynet? Should start with SNP. Can you take another photo showing all parts of all the boards?
@irrebo, you are probably right 🙂 , according to this russian nuforce site it is SNP-Z30 in the ref 9 v2se amp.
pcb shows Z30Y, maybe some differences to drive capacitor bank, higher capacitance, Nuforce wanted
Where is the 5V (thin red wire??) connected, series connected to the black wire ? Or separately?
- Power Supplies
- nuforce amp board hypex (or any other brand psu)
