Hi
Anyone pls share aud200u amp schematic or layout.thank you
Hi
sir manoj private message inbox is full
we can not recive shematic from sir manoj
Hello guys
a friend of mine found that I made a errata in my redrawing of the AUD600 that mister Manojtm made I forgot to add a 100uF 25V cap on pin 8 from the 555 to pin 1 negative side of the cap
here is the link with Sprint file please only use for diy no to " $$$$ "![]()
https://personal.filesanywhere.com/fs/v.aspx?v=8d6c65885a6276bdab6a
Best Regards
Juan
Hi
thank you and sir manoj for last version .
Hello guys
Best Regards
Juan
Hi
good time
which program can open your PCB filees >
lay file
Greetings mr.manojtm
I want buy your amp module aud200 and aud600
Pls reply i am waiting in few month
Thank you
Thank you
Hi hadi,
This is my last project. I didn't test right now
AUD600i is Sigma delta with external osc.
MANOJ
Hi
your class D amp is best i have until this time.
power full with quality
this amp is good too like them
Greetings sownel,
Pls wait few more days, busy with another project after i will complete aud600
Greetings hadi,
thank you for the comment
MANOJ
Greetings hadi,
MANOJ
Hi hadi,
MANOJ
What IC type for external OSC and U2a, U2b ?
Hi All,
AUD200D PCB 95% completed 🙂
Size 49mm x 134mm fix with 2.5" 3mm thick L clamp
MANOJ
MANOJ
Hi All,
MANOJ
looks good
Hi All,
MANOJ
Greetings sir.
How to buy your board
Pls reply mail stanimorin@gmail.com
My AUD1000SD i tested with VER2923-223 coil craft coil with DC +/-50v supply its give best sound quality fsw=435KHz(after @10 min it s reduced to 426KHz) MOSFET = IRFP250N; coil & mosfet cool
power out put is 220W @8R 410W @4R True RMS
MANOJ
MANOJ
MANOJ
i like it
- Class D
- My class D amp
