How to build a 21st century protection board
A 6 cap board would likely fit. My supply actually holds 8 per channel, 2 boards of four joined with CRC resistors. The schematic is below. I'll try to get some better pictures.
Grounding is simple, just return all your grounds to each supply (amp output, amp input, and speaker return). If you are using dual transformers, treat each channel like a separate amplifier. Add a separate ground loop breaker to each supply ground.
SMT is very easy to work with. It just takes a bit of practice. Tack down one pin, warm that pin back up and align the part. Once it's straight, solder the rest.
Oh, that's clever. I didn't realize that the PSU boards are not identical.
Is it something like I commented in the picture attached?
If my capacitors fit your boards (I have these HC2A688M40050HA SAMWHA - Capacitor: electrolytic | TME - Electronic components ), maybe I can use your boards and make two separate smaller boards holding two extra capacitors?
Or is it too complicated?
How important is to have the quick power shutdown PSUs in your opinion? Is it worth it to sacrifice capacity to have rail shutdown, or should I have maximum capacity without controlled rails?
Thanks a lot.
Yes the resistors are the bottom below the mount bracket. There's also bleed down resistors and ground links. They use TO-220 rectifiers that mount under the input board to the mounting bracket for cooling. The quick shut down circuitry is on the bottom side of the output board. it looks like your caps use 22mm 4 hole mounts. I've got these boards laid out for 35mm snap in caps with 10mm spacing, so they won't work with those caps.
It can also be connected to a pair of emitter resistors for current sensing, but can also connect with I2C current sensors.
Just came across this thread while researching protection systems for my project, and I would like to ask how you'r implementing Current sensing as I'm not clear about how to connect this? Bearing in mind that my lateral Mosfet output transistors don't have emitter resistors. A diagram/pic would help.
Seb
The current sensing is done by measuring voltage drop on the emitter resistors, which obviously isn't going to work in your situation.
I'm in the process of figuring out the best way to add Hall Effect current sensors to the supplies as an alternate option for current sensing. This could be an in series module with the supply rails too. One option I'm looking into is a ACS758. It could be connected to one of the AD converters on the Atmega328, but would require two AD converters per channel (yuck!). Another option would to use a comparator and have it tie into the existing current detection input. I'll likely go with the latter when time permits.
Boy it is a long time. I already forget about it. It is a simple circuit for those that does not want to use a micro. Also it isolated the amplifier output from the circuit and the best it is cheap to built. Suggestion next time make sure that the current sensor has mounting holes. The first ones I overlooked it and I had to glued it to a pieces of isolation material to be able to mount it. Also you can buy it up to 200 amps.
Hi Tauro
It does look like a nice standalone design. If you could squeeze DC offset detection in with it, it would be a great option for complete speaker protection.
I'm also looking to add mine to the supply rails instead of the output. I would prefer to monitor the current going into the amp as opposed to out as a complete protection package.
