What is wrong with op-amps?
Nope, no significance to that "test" whatsoever, and of course, there's no controls. If you want to do things right, do things right. If not, all you're doing is expending other people's time and energy to obtain meaningless "results."
Yup. Bear, please, controls are necessary. As long as they are negative.
(Positive controls are best avoided, anyway, as they will not be "appropriate" in this test. It's not really important to find out whether the listener could hear differences others have proven to hear in a controlled test).
http://www.diyaudio.com/forums/digi...native-post-dac-filtering-32.html#post4462498
WTF are you talking about??
It's a proposed piece of hardware.
What "controls" do you want??
A straight piece of wire is not good enough??
You take the box, do whatever tests you wish - control yourself any way you wish.
There is no specific "TEST" specified.
It's a box a piece of HARDWARE intended to increase the measureability of opamp distortion.
If you think the string of 10 will NOT increase the distortion, then say so, and state why.
After that you can do whatever you wish. I proposed measuring it first.
Are you afraid what the measurements might show?
Then listening to it.
AND then if people like YOU just happen to not lie and they hear a difference
between each "channel" THEN perhaps more "controlled" tests (which are more difficult to set up and more time consuming) could be considered.
Aka, one step at time.
And, although it is obvious, self-evident, to some extent this is a crude approximation of the cascaded signal path found in most recording situations, that being multiple opamps, apparently this is an elusive concept? Of course here the aim is to use identical opamps in the (vain?) hope that a "sonic signature" will emerge that even those who have difficulty hearing such things will find it audible and clear. (obviously, a real recording chain is more complex and the opamps are a mish-mash of types and brands - we're not ready to look at that, this is more basic).
Ok now, Stewart?
So, what's the problem?
Are you afraid you and others might detect audible differences that do NOT go away when DBT'd??
And, should it not "work" and show nothing, chalk one up.
It eliminates crossover and thereby eliminates crossover distortion. It eliminates gm doubling in the output stage. It changes the supply current waveform from a half wave rectified sinusoid (with attendant high harmonics), into a full sinusoid riding atop a DC bias (with no extra harmonics).
Spectrum of "before" (without external current source) shown below, notice 58% 2nd harmonic at 30 kHz and 3% 7th harmonic at 105 kHz. How good is your power supply at 105 kHz? How good is your active circuitry's PSRR at 105 kHz?
_
Thanks Mark, quite thorough.
_
Nothing terribly remarkable about any of that--of course that's what's going on. So instead of a totally synthetic work-up that looks scary, what's the harmonic structure of ____ opamp driving into ____ load to achieve that kind of current demand?
P.S. Something like a OPA1642 has ~40 dB PSRR at 100 kHz, too. PSU will need to be characterized, but with the bypass, it'd be pretty safe to say < 1 ohm throughout the range of interest.
I was proposing a string of 10 x 2 with the ability to A/B or A/B/X between the two.
(two separate and parallel stereo channels)
In the case of a unity gain set up, one might be able to set gains so that one could switch between a "wire" and string A or string B.
Measurements would be the first part.
The second part would be "casual listening".
Potentially with the box being passed around for impressions.
Anyone receiving the box could do properly controlled tests too.
Assumption: if the box goes to 10 people and 7 or 8 consistently pick "A" or "B" as best or say that the two sound different, or maybe all 10 say that, or perhaps it is 50/50 (essentially no result), then some information has been gathered.
There are a number of measurement tests that I could foresee using the board, and a number of variations in the subtle details of the circuit to try. Those versed in the art ought to find these variations self-evident.
Bear, let's step back. What do you want to test? I.e. what's the hypothesis being presented? Perhaps from there, a clearer experimental design can be made. This, as it is proposed, has no clear start or end goals.
As far as I can tell, you want to switch between a wire and 2 different 10 opamp-long unity gain chains. You wish to characterize the response of said chains, then circulate a box containing said 2 circuits and some sort of switching hardware to allow the user to pick between A and B on their own time and develop a preference.
_
Mark what circuit/device is that, giving 58% THD??
Jan
My guess was that he wants to compare a wire with a chain of 10 opamps with total gain 1, both from a "measurement" and "listening" perspective. And have some fun in the process.
I would only suggest that, depending on the source and load characteristics, the wire may be "worse" in the sense that the opamp chain could perform some "better" impedance matching / driving. Up to Bear to figure out how he wants to address this.
Daniel (Dr?),
The PSRR and the CMRR are often intertwined by real world circuit impedances. Spray noise around and something else picks it up.
To get 1 ohm of bypass impedance at 100,000 hertz you would need in theory 1.59 microfarads of capacitance. Now when I look up http://www.mouser.com/ds/2/293/e-upj-876311.pdf the 100,000 hertz impedance for a typical 1.5 uF capacitor it is closer to 10 ohms impedance.
If you look at how PSSR is measured for the manufacturer's data sheets it is really a bit tricky and the numbers shown will not be reached in most real circuit layouts.
Bear, it sounds like to you trying to demonstrate that many people can hear a difference between different opamps in some particular case, the one case you propose.
However, the argument that has been going on here is not that different opamps produce different distortion characteristics. The argument is that is more like this: In a simple one or two stage line level audio preamp, the distortion of opamps is so tiny, no human could hear it.
Therefore, some people seem to think you are trying to demonstrate something that has not been at issue here.
Also, people have been asking that you state a question you are trying to answer with your experiment. For what you have proposed so far, it sounds like your question might be something like: What percentage of forum participants can perceive a difference in the sound of 10 opamps cascaded in series? ...Something like that, you could clarify if you are trying to find an answer to some question or not.
Then again, maybe you are just trying to give people and opportunity to hear something for themselves that they may not have heard before. If so, fine with me, but some people here will point out that even if people do hear something different between opamps with your circuit, they still could never hear it in a simple line level audio preamp. So, to them, you will not have done anything to resolve what they perceive as the basis of the ongoing dispute. Something like that, maybe they can elaborate.
Ed, yes, you'd want to bypass with something like a 100 nF ceramic (which is almost universally recommended, as close to the pins as possible) + 10 uF electrolytic.
But your point to the overall complicated nature of the interconnections is why real-world tests are needed.
Mark, note that I published my results for the experiment asking the question, "How many IC op-amps (in this case OPA134) configured in unity gain needed to be placed in series before I can distinguish the chain from a straight wire, ears-only?"
The answer in that case was about 6. Test protocol, described in my article, was paired forced choice.
Jan, "THD" is merely the label that LTSPICE attaches to a number it computes during Fourier analysis.
What the computed number is, in fact, is the RMS average of the harmonics (omitting the fundamental).
The printed value "61.206% THD" in post #2279, is just the RMS average. I copied harmonics 2 thru 11 into Excel to show the calculation, see below.
You would need to build a series of individual PCB's optimized for each op-amp being tested with the ability to instantly switch between them. If output levels were equal you might still notice differences but i recon they would follow specs. Ultra low distortion op-amps might sound better (to some) but others who are used to a bit of distortion may well disagree.
You are right. What it does is simply turn off one output device making it into a single-ended output stage, making the thing that provides the external current into the se load impedance. Assuming the extra curent is sized to the max required output curent. If it is less, it just displaces the xover away from zero output. Something like a small-signal version of Douglas Self''s Cross-over displacement patent.
In Morinix example above, the LM334 is the se output stage load. That is an improvement?
Jan
It is. The pull down resistor version was ABX tested at Alesis in the late 90's. Greg Timbers of Harman Everest K2 fame uses it too.
