Yariss: mile Hi mr Mile, please can i replace the bc 550C with the bc 547? thanks in advance
Yes you can.
Yes you can.
Mile, I have Dynaudio BM15P monitors, they are 4 ohms and require 100-250W amp power. Which amp of your designs will be the best match for them for small home studio work?
Ranko
Ranko
Ranko
SR150
Which preamp and PSU shall I use for this purpose? I had in mind Apex SR PP8, and for PSU I am not sure. Is there any PSU that can be used for both amp and preamp? Shall I use this http://www.diyaudio.com/forums/solid-state/222083-apex-hv23.html#post3212457 PSU with protection (first image on page) or this one: http://www.diyaudio.com/forums/solid-state/173462-studio-reference-amplifier.html#post2303230 ?
There is PSU40 and PSU60
Which one?
Is this change significant compared to original schematic? I found PCB for schematic v1.0, and I am puzzled if this 1.1 is better and why? 😕
Also, do all transistors have to be matched, or only input / output pairs? Is it sufficient to match Hfe with multimeter, or they must be matched with bigger voltage and current?
Thanks,
Ranko
SR150 upgrade
Thanks,
Ranko
Thanks,
Ranko
Use SR150 V1.0 schematic.
One button on-off switch.
Nice... can be use main power button..
What do i need to change if i use 12v/30amp relay?
Circuit will work with 12V relay without change.
Thank you..
SR60
Can you, give us ,the limits of voltage rails ? 🙂
Thanks,Alex
2sa1943/c5200 for output devices limits supply rail to less than ~60Vdc, but I would not use them above 50Vdc.
Their high voltage SOA are terrible.
SR60
First layout try....
Board size : 92x100mm
- Studio Reference Amplifier
