Definitely let us know how it sounds. I looked at them but thought it was too expensive considering the price of other amps.
$6.68 for a bluetooth amp, including shipping, too expensive?
Have Ghettos become too poor for blasting?
Just find one TPA3116.
New TPA3116 CSR64215 Bluetooth V4.2 Digital Amplifier Board 2.0 2*50W APT-X AUX
Would be nice to find one with Bluetooth apt-x.
There is one with the 8945 chip but someone pointed out they didn't mention it was apt-x capable (even that chip should be). However, that board had no Aux in and costs around 40 (Aus)
I've not tried different power supplies with the tda8932 amps.
With the tpa311x amps, my favorite power supply is the Connex SMPS300R. But I haven't tried the power supply in my picture with the tpa311x amps.
Here's one ebay link for that power supply. Note there is at least one variation on it. I have two of these, the model number appears to be WX-DC2416.
Hi, concerning the WX-DC2416 power supply:
- how does it work?
- did you perform any electrical test?
- does the power supply switch normally on with a big capacitor (say 6800uF) on its output?
I’ve had some negative experiences with cheap chinese SMPS, so before buying another one, I try to get more information.
Haha, wow, we posted at exactly the same time. That is a good find. I am just a little confused by the front part of the case. It seems to have some sort of socket. Why put it in a case if you still need to plug in some sort of interface at the front? (I assume that is for volume control and power on/off??)
1. how does it work?
2. did you perform any electrical test?
3. does the power supply switch normally on with a big capacitor (say 6800uF) on its output?
1. Seems to work OK. I put it in the enclosure pictured a few posts back with two of the tda8932 mono boards. No issues so far. Hard to say how long it will last or if the performance will change over time. But for a super cheap amp build, I think it's perfect.
2. None, other than hooking up a DMM to verify the output voltage was in fact 24V. Somewhere in this tpa3118 thread there's a bit of discussion on this power supply. Someone put it on a scope, and showed pretty decent performance (relative to the super-cheap price). IIRC, performance improved measurably after the mods.
3. Haven't tried that, so I can't say! It does have short-circuit protection, so I'm sure there's a capacitance amount where it thinks there is a short and shuts down. I did try to use it to hot-rod a dustbuster (small hand-held vacuum cleaner). The dustbuster's rechargeable batteries degraded to the point of being useless. So I thought I'd give this PSU a try in that role. But it appears the motor initially looks like a short, so the PSU would go into shutdown after less than a second. Note I tried several SMPSes in this role, and they all exhibited the same behavior. I could only get the motor to turn on with batteries or a linear PSU.
This is my first time working with these cheap SMPSes, so it's hard to say how they'll perform in the long run.
Jensen567 http://www.diyaudio.com/forums/clas...ing-them-everything-comes-64.html#post4644010
primary cap: United Chemi-Con KXG EKXG251ELL221MMN3S (220 uF / 250 VDC), mouser part number: 661-EKXG251ELL221MMN
My primary cap is 100uF/400V. Why 220/250?
Sanwu's Taobao listing for that amp doesn't have any details about the connector. I'd guess it is there to simplify integration, if integration is desired.
I can't seem to find the board on its own.
Or the bare board for 1/2 the price.
TDA7492P 50W 2 Wireless Bluetooth 4 0 Audio Receiver Digital Amplifier Board Aux | eBay
With this PS.
100W AC DC Converter 110V 220V to 24V DC 4 6A Power Supply Switching Transformer | eBay
With this PS.
Don't see the apt-x there.
Oooops. You are right! Well spotted.
But that module looks exactly like the CSRA64215
http://www.ebay.com/itm/CSRA64215-4...339426?hash=item43e310d2e2:g:nJwAAOSwV0RXsYYW
Still on TDA8932.
Today I hooked my little module to a polk speakers plus polk sub. Now I have basses more then enough, a lot of bass and my impression is that highs are weak.
Until now all my tests was with car speakers, very powerful, but still car speakers.
Sound is completely different and is hard to have any conclusion about flatness, lack of basses or highs.
For input I use my archos multiplayer and I don't know what is the right input level.
Any ideas ?
Any ideas ?
TDA8932 is sensitive to its power supply and in my experience its impossible to decouple that well enough to get pristine highs. But with a higher load impedance the power supply becomes less critical - to raise the impedance of my speakers I use output transformers and this cleans up the highs nicely.
I'd definitely not recommend car speakers with TDA8932 as they tend to be rather low impedance (due to cars having low voltage supplies).
it's a CSR8635 on the 7492 - no aptx
- Class D
- Fasten seat belts. TDA8932 pessimistic review.
