Wrong. I've lost count as to how many times I've said this. Slew rate is not a measure of power bandwidth which is the popular misconception. It's how fast an amp recovers From input overload, and has little to do with linear operation. That's why it's tested with a very fast rise time square wave. This input over loads the diff input ( the positive in has full signal while the negative in is still at zero (due to the slight delay of the feedback signal)) I'm not going into detail again. So why is it such an important spec for something that has very little to do with linear operation?
Surely you should tell the manufacturers, starting from the triassic period of integrated circuits (the triassic part is arguable) that they've been using the term wrong. http://www.ti.com/lit/an/snoa852/snoa852.pdf
P.S. They're all interrelated, albeit overload recovery has a lot more going on than would ever be indicated in slew rate.
"it's how fast an amp recovers From input overload"
I don't think that is quite true, either! "Recovery" is not included.
As said the DUT is driven by a faster square wave that it can handle, the output becomes a ramp as (typically) Cdom is charged by he available current in the bias chain. This ramp slope is measured and becomes max slew rate, V/uS.
So a margin is required to be added to ensure that the amp is never driven into slew rate limit. I believe I am not just splitting hairs.
Really? I've lost count as to how many times I've said this. Slew rate is not a measure of power bandwidth which is the popular misconception. It's how fast an amp recovers From input overload, and has little to do with linear operation. That's why it's tested with a very fast rise time square wave. This input over loads the diff input ( the positive in has full signal while the negative in is still at zero (due to the slight delay of the feedback signal)) I'm not going into detail again. So why is it such an important spec for something that has very little to do with linear operation?
This is a fairly unclear understanding of all the issues. This way of looking at it will not give a clear picture of what happens in the continuum of input error signal vs output. First of all an LTP is never linear there is a transfer function of input voltage vs output current (tanh) which becomes progressively more non-linear as the total bias current is reached at that point it is maxed out. This current and the comp cap. give a maximum rate of change of output (slew rate). The frequency where you just reach this limit at for a full output sine wave is the industry standard definition of full power bandwidth.
Input overload recovery has a very different standard definition which usually is a measure of how badly, for instance, taking one input to the rail breaks internal bias circuits, etc. and the part has to recover. Looking at some data sheets will show pictures of parts going to sleep or going to the other rail for a few microseconds, etc. A square wave applied to a totally well behaved amplifier will make it slew at its slew rate to a final value. No where I have been is this considered input overload recovery.
You need to be careful and differentiate between raw slew and slew enhancement. The OP275 is actually a slew enhanced bipolar input for instance. 3.5nV with an H bridge input should be easily doable and could easily be >100V/usec.
Sure Scott - I meant commercially available units specifically. No doubt with a new design its possible.
Chester
What you write doesn’t relate to my post that you quote.
George
Several +-5V parts around don't know about +-15V.
Are there any very low noise (lets say <3.5nV/rt Hz or 2pA/rt Hz) opamps that have 100V/us SR's?
Tons of. LMH5401 has a gain-bandwidth product of 8 GHz, slew rate is 17,500 V/µs and noise is 1.25nV/rtHz at flat band. As a side, distortions (HD2, HD3) are <96dB @100MHz.
Oh, I forgot to mention, it's a VFA. There.
P.S. High voltage (+/-16V) THS4022, 350MHz, 470V/uS, 1.5nV/rtHz. Also VFA.
But that's a differential RF amp for 50 Ohm systems with Ib noise up the wazoo.
THS4022 - Gain of 10 stable.
Are slew rates tested with a square wave? Then the diff input gets overloaded. Look at the voltage across the + and - inputs in the first usecond
And a tanh transfer function is very linear close to zero. And emitter degeneration broaden this linear range.
I imagine that the shape was determined based on a set of round batteries internally stacked, I don't know, If that is the case that is just poor design, you can design batteries into flat packages and have a much higher density package than a round battery and not waste the space caused by putting round batteries next to each other. If that isn't the reason for the shape then I just don't get it for packaging reasons.
Pono Player Teardown – mike beauchamp
But neither are linear in the strict sense nor are JFET's, the distinction is important. A bipolar LTP is quite non-linear long before slewrate limit. Daniel posted the classic description from TI this is the way the industry looks at it.
Sorry about my confusion. This is what I learnt in my post graduate EE analog electronics course ( Grey and Meyers textbook) 30 years ago. I guess the definition of slew rate has become analogous to full power bandwidth.
Please read the link I provided. It addresses just that, and as Scott says (and he should know better than, well, pretty much anyone 🙂 ) this is the industry standard.
I know about some of those. They are not designed for audio - I see Scott has already answered.
I do wish you would stop coming back back on me about VFA vs CFA. As I have pointed out numerous times before, I have never been pro either over the other.
Tiresome. But then again this one dimensional approach is to be expected from your sort.
https://en.m.wikipedia.org/wiki/Slew_rate
I know about some of those. They are not designed for audio.
Nice try deflecting. So can you give three clues and three pointers about what is and what should do an opamp "designed for audio"?
I'm sure the semi industry will remain forever indebted to you.
Read the ******* data sheet for starters.
- General Interest
- Everything Else
- What is wrong with op-amps?
