Why would or would not the DC resistance of one driver affect the Qts of the other?
Two exactly the same drivers wired in series don't change Qts over a single
unit because the ratio of the variables involved in a calculation remains the
same.
You'll find in books following formulae to calculate TS parameters once
you have recorded impedance vs. frequency.
Ro=Rmax/Re; Rmax= max value of Z at Fs
Qms=(Fs*sqrt(Ro))/(F2-F1); F2,F1=frequencies at Rx
Rx=sqrt(Re*Rmax)
Qes=Qms/(Ro-1)
Qts=Qms/Ro
Or getting it more simple. For a given input voltage:
1. Two drivers in series - total SPL is the same
2. Two drivers in parallel - total SPL is +6dB
But note that the current in the parallel solution is 4 times the serial. So power is +6dB for the parallel (i.e. 4x).
You don't get nothing for nothing. Matching to amplifier capabilities is more important.
Like this file...
So no matter parallel or series connection, Qts never changes?
https://www.youtube.com/watch?v=WvIRsDHFiis
Yes, that is true.But note that the current in the parallel solution is 4 times the serial. So power is +6dB for the parallel (i.e. 4x).
Yes, that is true also.So no matter parallel or series connection, Qts never changes?
