Hi Enrico,
The sad news is that Tibi shipped the boards on 27-7, but so far I haven't receceived them.
Tibi is pushing the expedition company to find out why it is taking so long.
I only need one day for testing, so I'm anxiously waiting.
Hans
Should I hold off ordering from Tibi until you have tested one?
The wait is frustrating, partially because the ability to implement corrective action with payment transfer is generally gated and long waits like this endanger buyer recourse in case things go awry. That's not to imply any impropriety, just a statement of one compounding factor. As diy goes, this isn't a cheap solution to volume control and the long wait is definitely frustrating. I can't fully spec my chassis until I have a unit in-hand, either.
badman,
[SIZE=-1]A front pannel design is available to download FreeCAD file here, or Acrobat Reader file here.[/SIZE][SIZE=-1]
If you can't wait till Hans get the boards and test, I can ship your order next Monday. It is OK ?
Tibi
[/SIZE]If you can't wait till Hans get the boards and test, I can ship your order next Monday. It is OK ?
Tibi
Have exported the front panel to WebGL. Click image and rotate with the mouse.
FreeCAD model
Tibi
FreeCAD model
Tibi
Thanks Tibi- I'll wait because I'd rather be sure, just expressing the frustration (which I know you're feeling too). Thank you for the front panel design- very helpful! But I'd still need to take a look at how everything goes together in terms of layout before I can move forward.
Rather than get 2 separate trafos it's probably cheaper to get one custom trafo that has 2 sets of secondaries to power the Maya and the BPBPs (2 in my case).
Is there any reason not to do that?
There is nothing against that idea when you can save on that.
Hans
Hans
Cheers
Hi tibi,Have exported the front panel to WebGL. Click image and rotate with the mouse.
FreeCAD model
Tibi
Perfect, was waiting for this
Sent from my ONE A2003 using Tapatalk
Btw,
I have noticed we have some new Maya builds here. I recall we had a topic with Maya builds as well
Tibi,
How much variation can there be in the AC voltage if 9V?
There is a diagram of how to connect the controller in SE, but no details of how to do so in Balanced.
Can the controller accept an SE input and yet operate as a balanced output? And how are these options chosen and controlled.
Hi buzzfob. One maya relay board is suitable for two se channels or one bakanced channel
Is this comment only relevant to the Maya being used as a complete volume controller and not relevant to the Maya - BPBP implementation?
- Group Buys
- Maya R2R Advanced Volume controller
