100W Ultimate Fidelity Amplifier
Offset jumping around with music playing is not a real problem. That would happen on any amp. Offset is only measurable with zero input or input grounded, no?
Glad it plays music and sounds good. Strange how rail fluctuations cause offset changes. Unless rail fluctuations were asymmetric.
No.
A changing offset is an AC signal.
adding an AC signal that is determined by the changes in mains voltage is adding non harmonic distortion to your wanted audio signal.
If wandering offset is inherent to a particular topology and interaction with mains voltage variation then to me that points to the need for voltage regulation of the voltage sensitive stage.
Might be inaudible as a fundamental frequency, but what is that doing to the amplifier's ability to process the audio signal and what does that excessive LF output do to the bass speakers ability to process the audio signal?
And how do you know it is only an extreme LF effect? Mains voltage variations are fast events.
F8S
Just for fun.
No, Mile, ALF16 are double dye, but same polarity, there are ALF 16N and ALF 16P. You can choose TO264 or TO3, 160V or 200V.
16 is the number of Amperes.
I made my FX8 with ALF08NP, both N and P type in same case, but they are rated at 8 Amperes.
Yes a i missed that ALF16 are double die = 2 same transistor type in one package...so i would be same situation as 2 output paires instead one
Marc
+/-50mV offset fluctuacions is ok without DC servo... can you post scope measurements?
I converted the second channel. I have taken some scope shots and am posting them below. I also played about 12 songs through it. It really sounds quite lovely. Whoever complains about the bass from lateral MOSFETs needs better speakers. This amp goes deep and the bass is tight. Really, really nice sounding amp.
I also monitored the offset more closely and it is actually quite acceptable.
