Very simple quasi complimentary MOSFET amplifier
first sound test on my main system.
Simply the best amp I have.
Sweet and profound to summarize .
Thank you friends for this amazing amp .
Greetings .
Thiago
563899d1470669292-very-simple-quasi-complimentary-mosfet-amplifier-20160808_120348.jpg
There is that Sweet word again 🙂
Congratulations Thiagomogi on a fine looking (and sounding) amp!
:cheers:
question: going 2oz copper, will alleviate the trace lift problem encountered by XRK while desoldering?
I would say yes, as I went on to build another amp (Apex AX11) made using double thickness (70um) copper and it is very durable. I did a few desoldering changes and had no issues. Any solder points on a wide ground plane though needs a lot of watts to heat up before solder will flow though. This is why sometimes small heat conduction reduction cutouts are added to pads on wide strips of copper.
The problem with 2oz copper is the price is 5x more than 1oz ($50 vs $10) for 10 boards.
Path - minus C7 to D7 Anode moved
Hallo.
So many many impressive information last days here- many to work up.
Holy Moly !
I have seen the connection from minus C7 has moved to Anode of D7- so
i have to brake conducting path to Trimmer/Emitter Q4 point.
In this position must placed a little wire now- not other way to solve 4.1
Board.
happy listening to successful Builder ! :eguitar: :sax: :violin: :note:
:cheers:
I built the new boards with the changes from post #1032. I am out of range on the bias. I can get one board down to 100mA but the lowest on the other is 150mA. That is with the trimmer at 1k. Sine waves look good and offset looks solid though I didn't let it run for very long.
