It's 2010 and what's your fav VAS transistor?
It's 2016. I accidentally got a bag of 2SA1541 "D" grade from an old small surplus shop in Thailand. After searched on this forum, seems 2SA1541 is rarely mentioned nor having its photo here.
Any advice if they are genuine? How can we make (simple) tests on them? Thanks in advance.
Nice find! These look like Sanyo video drivers - and great low Cob value. Good high voltage rating and decent current. Will probably work well and similar to KSA1381/KSC3503.
http://pe2bz.philpem.me.uk/pdf on typenumber/0-9/2SC3956.pdf
Were they cheap? I have found great success buying bags of 20 to 40 of these types of transistors from Aliexpress (typically $5 to $8 a bag).
@xrk971
Thanks. Quick look on the datasheet, their Ft is impressive. This one kisses 150MHz at 5ma ( A1381 required 10ma). The down side is Hfe i.e. only ~60-70 but consistent among them.
I got them a while ago. I think it was US$40 for 200 pcs taking risks they might be fake. I might create a simple amp to see if they are genuine.
The low hFE would not be as great a problem when they are used to cascode another low power high hFE fast fT transistor.
They could also be used as the second transistor in the dual transistor VAS as shown in Blameless by D.Self.
aAnd as the pre-driver in a triple EF output stage.
SOT 223 package is easily capable of 1W dissipation and this meets a lot of VAS requirements. If the Cob of DZT5401/5551 is not low enough for your ultra low distortion SOTA laboratory project, then have a look at more SOT223 package types such as BF720-723 series. These are actually specified like the old Philips BF467-470 favourites in TO202 and TO126 packages. NXP, Infineon and On-semi are manufacturers so there shouldn't be too many supply problems.
http://www.mouser.com/ds/2/302/BF720_722-840010.pdf
http://www.mouser.com/ds/2/302/BF723-840309.pdf
From experience, Diodes Inc. BJT datasheets are often brutally honest in specifying their worst case numbers, like 6 pF Cob when the typical figure quoted by other manufacturers for similar product might be 3pF. It's misleading to compare parts by the only figures that appear when there is often little practical difference to get excited about. Too bad you already spent the money though 😱
The power handling of sub-minature SMD devices can be varied considerably by adjusting the amount of PCB copper attached to its collector. A degree of experimentation is required though - but the data-sheets are relatively conservative on the signal sized devices.
