100W Ultimate Fidelity Amplifier
BX22
Three days ago, I modified AX11 using +-90VDC with cheap and easily to find transistors, almost like BX22. In simulation, I can achieved very high slew rate and low enough THD. I sent it to my social media friend (I never meet him before). He made PCB layout and test the prototype in almost 2 days only. He satisfied the result.
Actually, I made it for +-120VDC, but he made +-90VDC for class AB and will make +-120VDC for class H.
This topology is easy to scale up.
Post the modified ver.here🙂
CCS in BX22 reduce voltage on CS transistor for about 30V (voltage drop on 10k)
Given the success of the FH9, I decided to take a totally fresh look at how to improve its performance and also to simplify its parts count. I think I have managed to do so, but it is so far removed from being an offshoot of one of Apex Audio's designs, I wonder if I should start a new thread or post here?
Basically it uses the venerable IRFP 240/9240 hexFET pair but in symmetric current feedback mode with a simple Vbe multiplier for temperature compensation. I have found that a simple resistor CCS is sufficient to achieve simulated THD of 0.00084% at 1kHz and 50v peak-peak on 53v rails. The simulated square wave performance is out of this world, clean and sharp up to 200kHz with no ringing. Oh, and did I mention that there are now only 7 active parts? Nothing exotic: BC546B/BC556B, KSA1381/KSC3503 VAS, BD139, and IRFP outputs... 🙂
Here is a teaser square wave closeup at 200kHz:
If we kept it in this thread, I would probably call it the CFH7.
Is this similar to FX8CF
Hi Apex Audio:
A think it is a bit different as it has fewer stages. Ok, I will post here as there seems to be interest...
CFH7 - current feedback hexFET amp
Schematic:
1kHz sine wave:
50kHz square wave:
200kHz square wave:
FFT spectrum at 1kHz:
HD components at 1kHz:
HD components at 20kHz:
