I share several hexfet amplifiers A9, FX14, HV23... with or without drivers, F100 is upgrade with BJT or mosfet drivers version, HV23 is without drivers but with 30mA bias in VAS... FH9 with 20mA bias in VAS can drive 2 output pairs without drivers.
There is F250 (mosfet version of SR250).
I feel much better now 🙂
Sorry Mr. Apex, I didn't know some of these amp. That's why we need an extended directory of Your Amplifiers.
You need list of amplifiers with threads and post numbers... there is A15 post #8 in this thread CFA mosfet amplifier with mosfet drivers.
Good to have extra pair of eyes. Some time it's difficult see errors even when it's in-front of you.
KSC3503/KSA1381 100mA device MJE340/350 500mA.
I think Andrewlebon will crank out an FH11 in no time once your layout is done. He has been busy - about 2 amps per day as far as I can tell. 🙂
FH9(HV) complete
Hello xrk971!
I'm sorry, but your name was rather hidden in my post. It would be nice if u could give a contribution!
I'm now going to bundle all data (schematic, layout, gerber, BoM) on the recent level of FH9(HV). I will not count up the version number, but make a difference between the 'standard' version rails 35V to xxV? and the 'high voltage' version xxV? to 52V called as FH9 and FH9HV.
In case you have better ideas, please let it know me! I also expect some suggestions for 'xxV'.
After you provided me with all data, I can do it rather easily. There is only one thing, I don't have: a schematic which can be edited. xrk971, you must have a schematic from u simulations. Ofc I don't know in which program u did it. Maybe u can tell me the program and provide the working file? In case, the schematic is in eagle, it would be great!
Hello xrk971!
Hello xrk971!
The simulation is in Tina format.
Hello Sonal
greetings is it possible to share sprint LAY files for 2 pair version
nothing like a try
warm regards
Andrew
nothing like a try
warm regards
Andrew
Hello Sonal
nothing like a try
warm regards
Andrew
This is the old layout that Sonal is working on to correct the flipped electrolytics on. I am looking at it and can't find any other errors, and do see that it is a beautiful layout otherwise. If one was in a hurry, this could be used with a manual (note to self) to flip power rail electrolytics and it should work. It's a surprisingly compact and simple 250w amp though.
Sprint file for FH11. Pdf files will be shared after andrewlebon has tested it.
@andrewlebon If you use with voltage rail of 55v or less then use 1000uF/63v instead of 680uF and 47uF/63v instead of 22uF.
There was one more mistake MJE340 was in place of BD140 and MJE350 in place of BD139.
Sonal Kunal - thanks! Looks fantastic. 😀
It's very convenient that pin outs for BD139/140, KSC3503/KSA1831, MJE340/350 are the same. Note that on VHEX+ amp, vzaichenko drives a pair of IRFP's with a single KSC/KSA just fine so it may still be suitable to use those drivers. I believe they may have slightly better noise/performance figures over the MJE's.
I have both so it's not an issue - just wondering which will give best performance.
Hello Sonal
greetings thank you for the lay files and your tips will make pcb today
warm regards
Andrew
warm regards
Andrew
Then you should get KSC2690A/KSA1220A.
Thanks - I will have to look into those. I think the 3503/1831 are video drivers and very high slew rate with low capacitance. These drivers have a lot of current capability - probably enough as headphone amps.
Nice pcb but it can be resize to 100x60mm.
When I was making layout I visualized mounting holes on all corners. But with 100x60mm, pcb mounting hole at top is not possible.
I'll make two version.
Sonal
Thats a wonderful layout sonal
reg
prasi
Sonal
I wouldn't dare ask to make it smaller 🙂
If it helps, I am using 1W 0.47R supply resistors in F9HV and they are not even warm. I also don't need/use screw holes on the edge with the OPS.
Beautiful and very builder friendly design though. The 100mmx60mm will mean qnty 10 for $10 from PCBWay 😀
I would like to mention that MPSA92 transistor will be getting quite hot when using high voltage rails and it will require a heatsink, which may present a challenge to some, since it is in a TO-92 package. An alternative would be to use a different transistor in a bigger TO-126 package instead.
Hmm... KSA1381?
2SA/KSA1381 will work, as well as every other TO-126 transistor that's typically used for VAS duty. Obviously PCB would need to be modified to accomodate different transistor.
- 100W Ultimate Fidelity Amplifier
