Based on Hugh Dean's AKSA 55
Not so fast Suresh! I spent a year on the Maya, and just finished about six months on the SAKSA!
The connection between the schematic, the dimensioning and the subjective listening is very tenuous and takes years to apprehend, if at all. Most designers don't agree with each other at all, and most work in a vacuum. Many of my amps have two, three or four people's thoughts in them. The 'tricks' are not the same between designers; I work with distortion; simply try to design which emphasizes the even order harmonics whilst reduces the odd orders. Even so I'm not dead sure this is the best way; transient behaviour in an amp is very important and not well understood even today. You need to be a detective rather than a scientist, and of course there is a lot of listening sessions and you need to have four or five listeners, not just yourself.
But it's fun, thankfully at 65 I still love it as much as I started out at 45.
Hugh
I wish a good travel to SAKSA!🙂
hi, i made this pcb but i wanna use 20v ish psu since my speakers are high efficiency and i already have 25v caps available. what resistors do i need to tweak for the different psu voltage?
i'm guessing r3, 4, 5 to lower values?
I build my first ever amplifier as a lower voltage clone of AKSA !
Well, referring to the pdf file attached to the first post. Dropping from 35V to 20V is a factor of 1.75. So to first guess you need to reduce R3 to around 28k in order to keep the LTP current at the right level; distortion maybe a little higher, the sound a little more mellow. If you can keep the same current through the input pair you can leave R4 unchanged.
The current through the VAS needs to be maintained too, so you want to reduce the value of R5 and R6. However, this does place more stress on the bootstrap drive because it will see a lower impedance to the rail (R5). You want around 1k2 on R5 and 1k8 on R6, or for simplicity you could try 1k5 for both R5 and R6.
A little experimentation would be within the spirit of the project.
Is it possible to operate this using two laptop power supply +/-19v?(one for each rail)
It can, but I'm not sure the performance is same or not. I must simulate it, first.
I think, this topology is optimal when using +-45VDC. Using higher than +-45VDC, the THD will increase significantly. Using lower than +-25VDC, will difficult to choose resistors bootstrap value (too small).
The challenge is to make THD lower as possible, but still H2 dominant.
bimo
Post 837.
In your amplifier, you have changed the current source LTP with 4 blue
led. It is better current source? It changed something in the sound?
Thanks.
i ended up building the original version and find the sound to be appealing. however, compared to VSSA the treble is not as refined- bit fatiguing, in fact.
I'm using bd140/139 for drivers. could somebody who has compared different transistors in this location chime in about the sound differences? I'm hoping the pricier 2SC4793/2SA1837 would be the fix, but from my previous experience with VSSA, slow driver transistors like 140/139 actually sounds more 'round'.
Greg made a small batch of PCB's. I don't think he made any gerbers available I can't remember if there was any artwork or not in this thread.
edit: there was artwork 🙂 http://www.diyaudio.com/forums/solid-state/168554-based-hugh-deans-aksa-55-a-2.html#post2218663
Tony.
From the above artwork link, is it possible to only extract the traces, make them pitch black and remove the silkscreen ? I recently built an authentic AKSA 55N and I truly enjoy this amp. Since it's out of production I'd like to make a similar one using the BAKSA while etching my own PCB. Is there a PCB dimensions or reference so I can know which scale to use..
Thanks in advance,
Eric
Thanks in advance,
Eric
You could try my artwork from the link below (Portuguese language, use Google Translator if necessary 🙂). Also see from post #614.
Construindo um Amplificador – SomShow Magazine
Search for the Dropbox link at the article's end. 😎
Rgds.
