100W Ultimate Fidelity Amplifier
Mr. Mile,
I am interested in this as a i/p selector. Can you give me the values/part nos. for each components? It can be made in a small PCB form to be mounted on front panel for i/p selection.
also sch for volume control would be nice too.
reg
Prasi
PCB is mounted on back panel only pot for select is on front panel. All resistors is 10k same as pot. Relays is for 12V 2x1A and IC is LM324 or any quad OP amp.
Sizing posts are odd.
The Sprint pic in post7727 shows the purple/violet out-line from:
01mm to 181mm giving a length of 180mm
and 01mm to 101mm giving a width of 100mm.
That 180 by 100 agrees with the size stated in the same post.
Why is a pdf giving a bigger size?
Why is Still4 seeing a different size using the same "Sprint" software?
The Sprint file shows the board to be 208mm x 100mm.
Sprint file juan shared has 3 output pair.
I use both cute pdf writer or foxit reader, cute writer make smaller pdf file size than foxit.
I'm sorry. I didn't notice there were three tabs in the Sprint file. The 2p layout is indeed 180mm x 100mm. The 3p is 201mm x 100mm and the 4p is 224mm x 100mm.
