Dual mono AK4495S with AK4137 and MCU/LCD DAC kit for $160
Hi Neslo,
below LCD board with menu button...
Where does the ir reciever go K? I can see 2 sets of 3 holes: one set (horizontal) has an smd cap or resistor fitted between 2 of the holes and the other (vertically aligned) set has all three holes unpopulated.
Thanks ,
Gordon
A good combination for electrolytic capacitors. Rubicon ZLH + Elna Silmic (or Towa)
Yes I'm aware of this board, I'm more interested in NODAC approach, and have read someone mentioned that direct DSD on AK4490 + HQPlayer sounds amazing
Thanks anyway
NODAC approach means no DAC chip in the chain = I2S > analog filter (signalyst, Acko board etc.)
AK4490 + HQPlayer is DAC approach = I2S > DAC chip > analog out
so if you are interested in NODAC approach than you can post your questions here, otherwise what 730user mentioned around amanero/xmos interface connected directly to AK4490/4495 DAC board is correct...
