wire enclosed that cannot get rid of heat easily is usually operated at 3A/sqmm to 6A/sqmm
wire that is cooled by ambient air can be operated at upto 12A/sqmm
There are two limitations:
Voltage drop along the wire.
Temperature rise, particularly of the insulation.
It is often reasonable to only consider average operating current when assessing heat loading. i.e. for a pair of ClassAB 100W into 8ohms amplifiers, one could use 0.8mm diam, or 1mm diam, copper wire in pvc insulation for average currents of ~3A and the insulation will appear cold (it won't soften).
Quick question regarding the output connectors;
Does anybody know if FASTON-250 series tabs will fit in place of the 3-pin outputs?
The wire I will be using is too thick for the connectors(12-14 AWG). I would prefer not to solder the connections right now, as I will be building a couple(conservative estimate) of amps in the future, and may switch around some parts.
Faston uses two holes in the pad and better/stronger if plated both sides.
Two, or three, adjacent pads @ 0.2" centres both/all drilled with two holes to suit the faston allows two/three fastons to be fitted, or using just one hole to use a two/three way 0.2" terminal block.
At least one of the fastons MUST be insulated, to prevent accidents. The gap between two insulating boots will be small.
Fastons come in three sizes: yellow, blue and red. I don't know which sizes fit which colours.
Thanks Andrew. The faston .187 series I use at work use the color Red=22-18, Blue=16-14, Yellow 12-10. I believe its the same for all amphenol/tyco faston terminals.
I always use the insulated terminals, they are worth the extra money in my opinion(I find they crimp better, and provide insulation).
Bridges for top photo (you need 2) GBPC3502 Fairchild Semiconductor | Mouser
http://www.apexjr.com/components.html
600 P.I.V. 25A 1" x 1" 1/4" Tab Terminal Bridge $2.50
600 P.I.V is Better.
Why?.................
- Power Supplies
- diyAudio Power Supply Circuit Board v3 illustrated build guide
