Look at this one on eBay Mini chassis Full aluminum Black Amplifier Case Hifi Enclosure DIY 132x42x169mm | eBay
Sent from my SM-G935F using Tapatalk
2004 LCD cannot fit in the one above, this one is cheapest that can do:
S 2207 Aluminum Enclosure DAC Case Amplifier Chassis DIY BOX | eBay
Only three inputs, so if there's no sound when expected I'll just try the next input. Only takes a couple of seconds to cycle through. 🙂
Sent from my X5pro using Tapatalk
Isn't this the one you ordered, only deeper, cheaper, empty and with no logo:
1706 F6 Preamp Chassis Full Aluminum Amplifier Enclosure Mini AMP Case DAC BOX | eBay
Your case looks more and more tempting to me, especially now I found it for less money, plus a possibility to enlarge digits on standard 1602:
Large Alphanumeric on LCD
Indeed it is. I've just ordered one and cancelled the Ali Express order. Thank you. 🙂
If you need to make some drilling and finishes - easy to make new own case. Wood case will looks more nice at least for me.
last case for my DAC
Alex
Alex
Nice idea. I've already modified the code to accommodate the 1602 - mostly the string length and positioning and then the paging of the setup menu and config instructions. I've already removed the double-digit generation code, now might have to add it back in!Your case looks more and more tempting to me, especially now I found it for less money, plus a possibility to enlarge digits on standard 1602:
I've included the large digits (from your link) into the 1602 display.
Also, I've uploaded a short video of the device's operation on a 1602 display with this change made:
https://www.youtube.com/watch?v=YdbP6XfOub4
If you want the code then let me know. Note that I've not modified any code relating to outputs, only the inputs, so further work is required.
Chris
Cool! I'd jump on it right away if I wasn't missing the I2C module for 2004/1602 LCDs, so I am now trying to (blindly) adjust VxD code for the only I2C I have on my desk, which is 2.42" OLED. I did hit the wall with global variable space (1.5k) used by Adafruit 1306 library, so I had to opt for an alternative u8glib lib. It's not as straightforward nor fast as AF, but at least it can be compiled.
Please do post the code, I think I will build at least one like yours.
Neb.
Neb.
Neb.
Will do. It needs tidying first before being made public, I'll aim to do that this evening.
BTW the Ali Express case order cancellation failed, so I'm going to end up with two cases now...!
Chris
Chris
Here we are, here's a version of the latest firmware but including the following changes:
- Modified to support both 2004 and 1602 LCD display sizes by updating LCDCOLUMNS and LCDROWS constant values (3 x 2 font credited to digimike, Arduino forum user)
- Added constants for cursor character and LCD address
- Added support for IR remote repeat code '4' as seen on some clone remotes
The main reason for the change has been to enable support for 1602 LCD displays due to the difficulty had in sourcing suitable cases for 2004 LCDs. Cases that support 1602 LCDs are available from multiple sources.
Chris
Cool. I like your implementation of the display and the encoder switch. Looks like something I might consider on a future build. Well done. Source code available?
Rick
Quick question that's a little different than the earlier post about balanced inputs.
Would it be possible to do two of the boards with one encoder to provide equal volume control for 4 channels? Not balanced, but 4 unbalanced channels coming off of a miniDSP.
Nice screen ZDR, will you share the code ?
Is it possible to reduce the size of inputs/outputs and increase the size of volume level ?
I will share the code, but not finished yet. You can change anything you want🙂Nice screen ZDR, will you share the code ?
Oled is a bit slow, since I don't have enough variable space to keep pixels in memory, so it has to redraw full screen whenever there is a change.
Hm, my usb port from nano board disconnects from PC when IR is connected. I am using TSOP34438, and it's correctly connected to controller PCB. Is anyone else experiencing this?
It was the pinout after all. The bom lists TSOP344xx but the link leads to TSOP324XXX. I bought from the link and I thought I had 344 which has reversed power pins.
- Analog Line Level
- Arduino based LDR volume and source selection controller
