Dual mono AK4495S with AK4137 and MCU/LCD DAC kit for $160
here we go...
I'm posting links to the pictures in original size that's why just links instead of thumbnails...
View image: DSC00579s
View image: DSC00789ss
View image: DSC00793ss
View image: BOM
View image: pin configuration
remote control functions:
- for the first time you need to pair your remote with the MCU, press "menu" + "right arrow key" at the same time on the remote control for at least 6 seconds, "IR OK" message pops up on the screen, then release both keys and pairing is complete, if no message appear try to attempt several times
- left/right arrows are volume control
- top arrow is source switch
- bottom arrow is filter switch
- menu button changing setting of the MCU
- mute button is mute
- middle button confirming commands
any other questions shoot...
I have both dac kit...single ak4490 with modified output stage tps7a4700 regulators and single not dual ak4495. Both are wery similar sounded. Output opamps are lme49990 and Ada4898. Have you any information if the constructor will make Ak4497 dac?
here we go...
View image: BOM
Thanks Kukynas , can you point me in the direction of a nice chassis for this dac?
here we go...
View image: BOM
Thanks for very sharp photos which confirms that 75 Ohm is also for the BNC connector.
The Pin configuration table is a bit difficult to understand for me..so I have the AK4137, Dual AK4495 and the XMOS board how shall the J1-11 on AK4495 board be set?
Where to connect IR sensor to the AK4137?
Do you know the difference between the board you mentioned
HIFI asynchronous digital XMOS U8 module USB IIS / DSD supports PCM / DSD-in Amplifier from Consumer Electronics on Aliexpress.com | Alibaba Group
and this one
Advanced version Italian Amanero Combo384 USB DSD 512 / PCM 384 module-in Solar Cells, Solar Panel from Electrical Equipment & Supplies on Aliexpress.com | Alibaba Group
What PSUs can you recommend..right now it seems like LT3042 is quite popular but I haven't listened to them..
Neslo,
in case of use of AK4137 board you need to set jumper J09, J10 and J11 look at Dual chip online mode (left channel) configuration under "set reference: (AK4118 plate /4137 plate) " on the bottom of the page, all other jumpers stays open (disconnected)
IR diode is located on LCD screen module sold with AK4137 board, I can send you picture of it if you want...
as mentioned earlier there is no functional difference between the boards and if you plan to use AK4137 upsampling capabilities you better invest in better quality oscillators and it's PSU than USB module as every incoming signal including USB will be recklocked with AK4137 chip and it's own oscillators, I can recommend this ULN PSU, one line for oscillators and second for DAC board, in case of opamp PSU I will use this one
Hi kukynas,
Thanks.
Yes please upload picture of LCD with IR.
Ok fine with USB board..and it get it power from the AK4137 board which then shall have the HQ PSUs.
Why do you choose TPS7A4700 regulator for the Opamps and not the LT3042?
in terms of PSU, my plan was following:
- 60W R-core transformer with 2x15V and 2x9V
- 1x9V supplying MCU board, MCU board contains LM7805 pre-reg which I plan to change for better one with higher current >1.5A, MCU board will supply 5V into digital part of AK4495 board, will keep those 3xADP151 where they are
- 1x9V supplying 2xLT3042, one 3.3V for oscillators on MCU (bypassing current ADP151 next to oscillators) board and one 7V for analog part of AK4495 board (bypassing those LT1763 regs)
- 2x15V supplying TPS7A4700 +/-15V for opamp stage, of course you can use LT3042 for it but make sure your AC won't exceed in any case 20V otherwise you'll damage reg chip, that's why it's safer to use TPS7A4700 for higher voltages...
Diy-DACs from Ultimate Star
Advantages - relatively inexpensive, and the exhaust is not fancy but good for demo board, good equipment, built on discrete power or the ability to use its power to the OS and primary digital and analogue DAC. Quite good secondary stubs - lt1763 analogue, adp151 digit (are individual for each chip, quartz). The full DAC DAC analog power and oh - embedded discrete shunt regulators. Support DSD (ASIO NATIVE). remote control.
https://ustars.world.taobao.com/category.htm?spm=a31…nTgS&search=y Ultimate Star Shop on Taobao
https://world.taobao.com/item/44710983763.htm?fromSi…0809223.33.QhjfXx full DAC
https://world.taobao.com/item/520401395018.htm?fromS…0809223.28.QhjfXx ак4495 DAC without power
https://world.taobao.com/item/526038366366.htm?fromS…0809223.39.QhjfXx dual ак4495 DAC without power
https://world.taobao.com/item/520834209345.htm?fromS…0809223.30.y1VvmE ак4490 DAC without power
https://world.taobao.com/item/527172582335.htm?spm=a…abe5-391b63f82468 DSD DAC Signalyst
https://world.taobao.com/item/44752822185.htm?spm=a3…a272-d9b95da6abb2 XMOS (suitable and Amanero)
е SITIME (Upgrade SITIME crystal version (two 24.576M, 22.5792M upgrade for ultra-low jitter crystal SIT8208) SiT8208: Ultra Performance LVCMOS Oscillator
https://item.taobao.com/item.htm?spm=a312a.7700824.w…p;id=520832497451 spdif Ак4118
https://item.taobao.com/item.htm?spm=a312a.7700824.w…p;id=523984212824 АК4118 and АК4137
https://yadi.sk/d/42vLgyR-r7mGE body sizes for a full DAC
https://yadi.sk/d/2RXbYbZNr7vJQ jumpers and accessories DAC without power
https://yadi.sk/i/-u_BoE1LrZaPY Jumper dual-card version
https://yadi.sk/i/404E2zyrr9XW6 remote control. activation. the remote control has to be - Apple (Tested model: Model No: A1156 emc no: 2086, ...)
"I made it according to the instructions from the picture. At first clamped two buttons with the first image and the inscription was IR_OK, then clamped the two buttons with the second image and also waited IR_OK. Only after this control started working ..." Dyadya_Fedor
https://yadi.sk/d/uxQLqNosrAaVH alternate logo approved developer Ustars
qchx88@163.com
communication with the developers more, please do not pull in vain! Only on substantive issues. Otherwise, the developer will not respond!
- https://yadi.sk/i/SO73qj1Zrg6wA dual power version - foto
- https://yadi.sk/i/dL955yJtrg7jE сDiscrete Power full version DAC
- https://yadi.sk/i/xog0Q5pyrg7qX ustars DAC output filter
Often referred to diy projects
DIYINHK
AK4495 - I2S over USB Audio JL Sounds
https://cirydac.world.taobao.com/category.htm?spm=a3…ttRM&search=y CIRY AUDIO.
https://shop36043292.world.taobao.com/search.htm?spm…scene=taobao_shop SURE AUDIO
Vega-lab diy-DACs
http://www.lynxaudio.net/%D1%86%D0%B8%D1%84%D1%80%D0…1%80%D0%BE%D0%B2/ LYNX AUDIO
Audio - ALTOR AUDIO ALTOR AUDIO
http://soundex.ru/?app=core&module=members&c…file&id=73480 ENERGETIK
Ôîðóì Âåãàëàá sergey367
Massive Chinese cheap diy As a rule, need to be improved.
https://shop35413239.world.taobao.com/?spm=a312a.772…15080705.4.msV7wX Weiliang.
https://shop35754574.world.taobao.com/?spm=a312a.772…15080705.4.Y7CFAy Юинг.
https://shop66230945.world.taobao.com/?spm=a312a.772…15080705.3.9wvwfh AI DIY
Drivers
https://yadi.sk/d/g2BE0jOkr7CPs xmos weiliang 1.61 , 2.23
XMOS(Ustars Audio).rar ? RGhost ? ????????????? xmos ustars 2.23 (Wave IO), 2.26
Luckit WaveIO modDrivers v3.34.0.7z ? RGhost ? ????????????? xmos ustars 3.34 (мод Wave IO)
Note - Driver Wave II no clicks by DSD on ASIO NATIVE
Quality players
Audio player software "Album Player 2.x" Ïðîãðàììíûé àóäèîïëååð "Album Player 2.x" [1] - Êîíôåðåíöèÿ iXBT.com
https://www.foobar2000.org/ foobar2000
https://www.jriver.com/ jriver
XMPlay Support , https://yadi.sk/d/kg2uku6grYXkm xmplay
Player settings under DSD
http://matrix-digi.com/pdf/DSD_Configuration_Guide.rar Foobar2000, Audirvana. JRiver
http://zvukomaniya.ru/kak-nastroit-dsd-na-foobar2000/ Foobar2000
How to play DSD files on Foobar | PS Audio Foobar2000
By Album Player is simple. Unpack the archive. Of EXTRA folder is copied with the replacement of the main folder and HTPC ASIO folder. Select the output mode you want us to ASIO. Go to the File Formats - ISO.DFF.DSF - Configuration - select NATIVE ASIO
Projects on LINUX
https://www.daphile.com/#download
Sonore ISO2DSD – V.A.M.P.
POWER
From the collective experience of the assembly - powered oh and primary analog power DAC is better suited discrete stabilizers. Primary power numbers - to taste, uses simple Ustars 7805 ... On the boards without power - 10 analogue DAC can be powered from the power ou plus, as
Figure 5 can be powered from the board or ak4118 ak4137
MisterTao: Leading Taobao Agent - Taobao Product - ??????????? ?? Class А OPAMP Power
?????? ????????? ???????/?????????? ?? Taobao ??????, ?? ???????? ???? OPAMP Power
https://world.taobao.com/item/523237220473.htm?fromS…4227019.39.uSsI59 OPAMP Power -CIRY
https://world.taobao.com/item/522950791695.htm?fromS…2014.21088516.0.0 Power STUDER900
https://shop35413239.world.taobao.com/search.htm?q=S…mp;initiative_id= Power STUDER900 Weiliang
https://world.taobao.com/item/1666478416.htm?fromSit…0978983.23.DOEyRq Power OPAMP by Erno (Erno Borbely)
https://world.taobao.com/item/524348240177.htm?spm=a…8516-ad4cd4b4f4e6 LT1963A Power
MisterTao: Leading Taobao Agent - Taobao Product - 78XX?? ????? 5V 12V 15V 18V 24V ????? ?? PCB 7805 Power
How to buy.
Aliexpress. sellers there are other fees. Prices are a little different.
http://ru.aliexpress.com/item/AK4495S-DAC-decoder-fi…etailNewVersion=2 Rose Electronic
http://ru.aliexpress.com/item/DUAL-AK4495S-DAC-decod…/32625139431.html jack Electronic
http://ru.aliexpress.com/store/group/HIFI-DAC-Amplif…8.100006.2.8EO8Ea jack Electronic
TaoBao- through intermediaries.
MisterTao: Leading Taobao Agent - Taobao Product - AK4495S DAC??? ?? ??????????? DSD IIS?? DAC
MisterTao: Leading Taobao Agent - Taobao Product - HIFI???? XMOS U8?? USB ? IIS/DSD ??PCM/DSD xmos
datasheet
https://yadi.sk/i/rjgwOMJYrg27D AK4495SEQ
https://yadi.sk/i/wTiOvucerg29i AK4495SEQ eva board
https://yadi.sk/d/DgIDuYK-rg2Cr AK4137EQ
https://yadi.sk/i/3VSJBCdCrg2Ez AK4118
https://yadi.sk/i/dzv2O1NGrg2Gr LT1763fh
https://yadi.sk/i/3Pf1zLperg2Un adp150
https://yadi.sk/i/xLgLuYYfrg2Lt реле, применяемое в устарсах
https://yadi.sk/i/II0KwmLJrg2Jv LT1963
https://yadi.sk/i/nr6YiRWlrg2QW ора1611
https://yadi.sk/i/TTsAG4o0rg2Ry ad797
https://yadi.sk/i/Z6MhwKvqrg2Tf lt3042
https://yadi.sk/i/PZnaSgLLrg2XK Lynx D70
Useful articles
Çàçåìëåíèå è çâó÷àíèå àïïàðàòóðû About DAC grounding and EMI filters connected. LYNX
Premium Audio Devices | AKM - Asahi Kasei Microdevices Ranging from DAC ADC SRC - AKM
https://yadi.sk/i/TzX0xT5yrZbm4 On the process technology in the production of ak4495 -SE, SEQ and 4490. The official response to the request from AKM lomonosoff. Until 4497 - the top (was) just AK4495SEQ.
Links to the audited stores radiocomponents
https://world.taobao.com/item/360518...?fromSite=main
Reviews of Ustars (There are many)
AK4399 DAC9 (V1.2) Äåøåâûé Hi-Fi - Ñòðàíèöà 114 Uncle_Fedor
Дий-проекты ЦАП - Ustars, Weiliang и другие проекты, #0 DJ
Thanks Kukynas. If you could check when chassis will be available again that would be great.
