100W Ultimate Fidelity Amplifier
It is depend on the compensation. My simulation did not show an overshoot on 100kHz square wave. Very high slew rate 😎
Ok, I just installed LTspice and can see that there are many mods. All the transistors seem to be different with the "Cordell" designation - is that the person who suggested that transistor?
I also see some very impressive specs typed on the main layout with PSRR at 105dB and 1kHz THD at 30W 0.002% ? If that is so, this is a superb amp.
What are the same specs for the baseline FX8 without the mods?
Next question is, how do I actually run the simulation? I get a message "can't find definition of KSC1845".
Sorry for the beginner at LTspice question...
You should read this: http://www.diyaudio.com/forums/software-tools/260627-installing-using-ltspice-beginner-advanced.html
Please use models that created by Bob Cordell if possible, because those models was proved to be accurate. Then use models that created and listed by Keantoken.
1kHz THD at 30W 0.002% is not superb amp, I have simulate much lower than that 🙂 You should look at 20kHz THD at large signal. Some designer does not really care about how much THD, they look at the harmonic profile.
Being new to discrete SS class AB, and coming from class D chip amps where 0.1% THD at 40w was considered good - 0.002% is very good to me. Most speakers are no better than -55dB so the amp is not the limiting step for sure. The harmonic content is important though (even order vs odd etc.)
Ok, I am going to have to read up on LTspice.
Hmm...never thought of that before. Right now the "pre-amp" is the headphone output from a CD player - probably safe to say no DC. Easy enough to measure. A "cap bypass" jumper or switch is a convenient way to do this.
I decided to increase the bias current to 150mA (up from 100mA) based on higher current figures used in Bimo's simulation.
I have to say how surprised I am at the beautiful sound quality from such a small and elegant little amp. How much of this sound quality is due to the nice Hitachi lateral FETs? I don't have a scope, but from what others have simulated or measured, what is it about this design that achieves such clean square waves?
Thank you again Apex for a great amp design.
It could be interesting for community to have your FX8 moded schematic....
Marc
Line outputs of CD player have output coupling caps - they are safe to be used with DC coupled power amplifier (one without series input cap). Headphone output (usually opamp based) probably has some DC component and is not suitable for DC coupled power amps. No matter how small that DC component is, DC coupled power amp will amplify it and send it to the loudspeakers. You can use your DMM to measure DC component on the headphones output.
If there is no DC on signal source (preamp) you can remove input cap.
Hmm...never thought of that before. Right now the "pre-amp" is the headphone output from a CD player - probably safe to say no DC. Easy enough to measure. A "cap bypass" jumper or switch is a convenient way to do this. ....................
Check the output offset and how it varies with vol pot setting and how it varies with which Source is connected.
DC coupled amplifiers need lots of protections to save damaging equipment when some innocuous fault occurs.
Ivan is aware
Apex is asleep !
I consider that the push-pull driver stage does the trick mostly. A further step to understand the magic of FX8 (and AX11) see the attached picture.
An unbalanced to balanced input signal transformer can also allow removal of input cap.
Input signal transformers are usually for balanced to unbalanced.
One uses a Balanced Impedance Source feeding a Balanced Impedance cable into the Balanced Impedance transformer and the output from the transformer feeds an unbalanced Power Amplifier input.
I agree. In class D land where I came from, we often use it this way to allow standard RCA unbalanced to drive balanced differential inputs on TPA311x chips to bypass input caps. The resulting lack of input caps and use of differential inputs (vs grounding one of the inputs) really improves the sound quality. I suppose in this case, perhaps the LTP can be configured for differential inputs? This would improve CMRR?
... In class D land where I came from, we often use it this way to allow standard RCA unbalanced to drive balanced differential inputs on TPA311x chips to bypass input caps. The resulting lack of input caps and use of differential inputs (vs grounding one of the inputs) really improves the sound quality. I suppose in this case, perhaps the LTP can be configured for differential inputs? This would improve CMRR?
What?
