Vicol Audio R2R Volume controller Builds
I was thinking it might be a good idea to share the builds based on the R2R Volume controls by Vicol Audio.
What do you think ?
It looks like some interesting builds were already shared in the previous R2R thread. Would be good to have them all at one place.
Feel free to share yours !
BTW we have an Interest check thread for the new version of controller, so if you are interested you can have a look.
Generally the build can look like
Source selector (Controller Bundle up 4-6 sources) -> R2R Volume Control -> Output Buffer (any buffer that you would like to use)
And you can get a simple and good controlled pre-amplifier unit.
OK
This is my Artemis.
A R2R Volume Controller (4 inputs and 1 direct) with a Salas DCB1 Buffer at the output of R2R.
Some pictures for the construction and the chassis are enclosed.
Inspired of "lemons" nice Volume control i decide to do something similar.
so here´s my Vicol R2R volume control. Works and sounds absolutly fantastic in my system🙂
Nice build. Which amp are you using, my dac+ volume control are similar)))
BTW, how did you wire the on/off button is it connected to your buffer as well?
Sent from my ONE A2003 using Tapatalk
Hi and thank´s!
Currently i use my new built PA03 Gainclone, my Firstwatt Aleph J have to step aside for awile.
About on/off, i wanted a green led for the standby function. Tibi told that i could use J7. So J7 and Vcc+ from the update firmware pin with a resistor works perfect with the standby called on/off on my VC front.
Hi and thank´s!
Got it so essentially you use this s button to power on the Maya only, not the buffer with it?
I was just thinking if the way to re-use the same power button for Maya and Salas DCB1
