I was thinking it might be a good idea to share the builds based on the R2R Volume controls by Vicol Audio.
What do you think ?
It looks like some interesting builds were already shared in the previous R2R thread. Would be good to have them all at one place.
Feel free to share yours !
BTW we have an Interest check thread for the new version of controller, so if you are interested you can have a look.
Generally the build can look like
Source selector (Controller Bundle up 4-6 sources) -> R2R Volume Control -> Output Buffer (any buffer that you would like to use)
And you can get a simple and good controlled pre-amplifier unit.
What do you think ?
OK
This is my Artemis.
A R2R Volume Controller (4 inputs and 1 direct) with a Salas DCB1 Buffer at the output of R2R.
Some pictures for the construction and the chassis are enclosed.
This is my Artemis.
Wow, really good job.OK
This is my Artemis.
Nice build. Which amp are you using, my dac+ volume control are similar)))Inspired of "lemons" nice Volume control i decide to do something similar.
so here´s my Vicol R2R volume control. Works and sounds absolutly fantastic in my system
BTW, how did you wire the on/off button is it connected to your buffer as well?
Sent from my ONE A2003 using Tapatalk
Hi and thank´s!
Currently i use my new built PA03 Gainclone, my Firstwatt Aleph J have to step aside for awile.
About on/off, i wanted a green led for the standby function. Tibi told that i could use J7. So J7 and Vcc+ from the update firmware pin with a resistor works perfect with the standby called on/off on my VC front.
Hi and thank´s!
Got it so essentially you use this s button to power on the Maya only, not the buffer with it?
I was just thinking if the way to re-use the same power button for Maya and Salas DCB1
- Analog Line Level
- Vicol Audio R2R Volume controller Builds
