Cresnet,
Is that heat sink really sufficient to run the amp or do you have to run a fan to keep the temp under control?
Sound is just superb, clean and clear mid / highs. Deep and low BASS. Total control of the speaker!
What did we told you? 😉 😀 😎
Cresnet,
In idle, the temperature is stable at 48C.
Even when when I play some music, it heats more but still safe, I am not using a FAN as I don't know if cooling the amplifier will affect the sound quality. or it should remain hot?
I like the sound, its very good and natural, I don't fell any coloring of the quality.
Really nice 😉
Congratulations!
Rick, what can I say?
I finished my FO Amp - Still Very Impressed!!!
Rick
It's Stereo time!Conducting some tests..
Deadly silent, Zero Noise, Zero Hum, even when nothing is connected to its input.
great work LC
What did we told you? 😉 😀 😎Sound is just superb, clean and clear mid / highs. Deep and low BASS. Total control of the speaker!
great work LC
Exactly
Thanks Cresnet 😉
Hi LC
any news about S version ?
I couldnt wait so I ve just order M version, but later I absolutely want to test biamping with 2 S. Any chance you could already post the drill plan for the S version please ?
I don't want to rush on this one, since I'm in the middle of testing of S and L prototypes, just before finishing PCB. After PCB is sent to production it's all too late for any correction to take place, so momentarily great care is taken to the last detail.
in order to test I have only ordered 1 hypex 1200A400 and then I was thinking about why the hell it would be so much better with dual psu. In fact its all about the problem of the ground current return and the fact that wires are resistor and then a voltage is showing up. But to avoid any cross talk or interraction between signal and reactive load we just need a clean Star and connect the signal ground to the star point instead of the "in-" of the FO, right?? let see;
For me there should be only one GND point to which analog signal is referenced and that is at I/V conversion inside DAC or at MM/MC pick-up. After this, all along audio chain to its end at speakers, any L & R GND short connection will introduce some new artifacts, interference currents and distortions not common to original signal in DAC or other analog source. So we need to avoid doing this and that is only possible with monoblocks or strict dual-mono amplifiers. In this way we get best stereo image with depth and resolution unmatched to common GND classic stereo amplifier.
At the moment I m using a dual mono smps+classD amp from Audiopower (each 0V only connected to signal ground input) and the result is excellent
http://www.gopix.fr/image-E88F_56C0B9D5.jpg
but its too brilliant in the highs (may be thd)... I hope FO will solve that and that FO+Hypex will give the same clean and powerfull bass as this DPA400. Cheers
Me hope you'll be happy.
Jay, I don't know what are you talking about here?! This is commercial part of the forum, therefore your assumptions have nothing in common with First One v1.4 amplifier since you don't own one, nor know anything about its schematics. Please post your theoretical philosophy in some other threads in Solid state part of the forum, not here.
Schematic of FO v1.4 is light years ahead of what you know regarding CFA (FO v1.2), so please take my words seriously.
Regards, L.C.
quote: FO v1.4 is light years ahead of what you know regarding CFA (FO v1.2), so please take my words seriously.
Thanks LC. I'm very happy with the result. Hoping for some dedicated listening time this weekend to put it through it's paces and let it warm up a bit. 🙂Rick, what can I say?![]()
great work LC
Looks like Flukeland.
About the vent. When i was calibrating the amp DC offset and bias they were floating quite quickly. I did not understand why. Later i discovered that my lung exhalations into diamond buffer termally changed the transistor sweet spot. When corrected the amp was stable.
For best sound quality you really need stable enviroment for the amps front end. And then magic happens.
Yes, I am not using a FAN at all, sound is just big, when its hot!
So I leave it hot!
Hi Cresnet,
I believe it's your own power supply in the background. If it's a great match with the FO you should create a thread to talk about it. Not many choices out there when it comes to high performance bipolar supply that can be used for Audio. More trusty manufacturer like you are most welcome.
BR,
Eric
BR,
Eric
Probably The Best First One measuring calibration equipment on the
First One's magic happens with just the right heat sinking at +/- 60 V/280 mA/45° CFor best sound quality you really need stable enviroment for the amps front end. And then magic happens.
FYI, all bridge structures whether it is Wheatstone, Maxwell, Kelvin, Wien, ... , Diamond or just a plain one, needs stable environment to be able to set it to equilibrium.
Hi Cresnet,
BR,
Eric
Alleged power supply that would beat SMPS1200A400 will be the winner for my
Hi LC
Is the PSRR of FO 1.4 much better than 1.2 ?
BR,
Eric
Yes. There are plenty housekeeping parts taking care of this.
Again, FO v1.4 is completely different amp, brief look to the photos tells everything, like someone has said before new version should more appropriately be v2.0
Hi Cresnet,
BR,
Eric
Yes, that's my own power supply running the FO module perfectly, I am also in the design stage of the new 1000W SMPS also.
I only have 4 volts drop at 225W output @ 4R dummy load @ 1Khz Sine wave!
Thank you for your trust.
Fo v 1.4 feed-back
Hello,
Just Few word to tell the fo v 4 is the best amp i ve ever heard.previously i had hypex ucd 180 the hypex ncore then fo v 1.2.
The 4 version is better than all hypex amp and than 2 version.
More transparency
More bass and détails...
I use a linear psu that gives much more results than the hypex ncore psu.
I know that lazy cat thinks the opposite but the thrue is so.
Congratulations lazy cat for your amazing job,
When. Do you release a 5 version...,,
Laurent
FYI, all bridge structures whether it is Wheatstone, Maxwell, Kelvin, Wien, ... , Diamond or just a plain one, needs stable environment to be able to set it to equilibrium.![]()
Hello,
More transparency
Laurent
Black Mamba from post #2719 is probably best sounding First One, silver multi-filament wire gives obvious excess of quality not encountered so far. Combined with interconnect and speaker cables made from the same wire and Graham Nalty connectors the sound really elevated to
- Vendor's Bazaar
- First One - mosFET amplifier module
