Bought these ,TIBO Edge 200 for the bedroom as there so cheap and could seem to get any used floor standers locally. Mainly listened to by my partner.I do my listening in my cellar studio on diy monitors.
So what do you get for £70 including shipping?
Of coarse ill have to peak and maybe tweak.
Anyone care to guess whats inside?
Is there even a crossover?
[/ATTACH][/ATTACH]
[/ATTACH][/ATTACH]
Drivers HF: 25mm soft dome
MF/LF: 2 x 165mm woofers
Frequency response (Hz) 50 - 20,000
Nominal impedance (ohms) 4-8 Power handling (watts) 50 (RMS)
1
1
Those tweeters look like £5
The woofers look like £8
So it's 8*4=32 + 10=42
Put some 8 £ chipboard plus vynil finish= total 50
Extra bonus: some cap for the tweeter
And also Two extra bobbins if very luxury + binding posts = we're exceeding !
Ok, let's reduce the cost
Tw 4 £
wf 6£
cabinets 8 £
cross & binding posts + wire 5 £
Job for assembling, glue, vynil coat 5 £
Now we reach 50 £! We're nearly done, just wait for the container to ship ...
Tw 4 £
wf 6£
cabinets 8 £
lol..
chipboard not that cheap here £30 for two large sheets.
The cabinets are decent fit/finish actual better than my last build!But then ive got no workshop facilities
What can I say ? Probably you can get some discount price when you hold the whole batch. Let's say a number of 5000 ?
The business enterprise would start with about 50000 ( $-£_€-etc )
The target is about 2000 pieces production or maybe more 😕
I forgot the acoustic polyfill !!!
About 500 for extruded puffled acethate 😱
playing the seventies album rely highlights deficienies, The seventies preferred electric bass sounds more like a double bass!
lack of damping?
lack of damping?
anybody interested in chiming in with tweaks please do so.
.Not going to change drivers just yet.Amazed i got waf approval in first place!
now you should try to put the coaxial on the double woofers 🙂
Thanks but im not not messing with these puppies! just need a mini dsp ,currently running on 2 way car active crossover.
the coax have a serious hf rise!
The only thing you can do with those is to use one woofer only and cut them in half.
Or, first remove a woofer and search for the crossover inside.
Not much to do.
Chipboard should be doubled in thickness - that could be a nice re-use: cut them in half and double the panels 🙂
Not much to do.
It looks like a woofer from the Fifties
Sometimes it seems to me that instead of doubling the coil value, some prefers to double the woofer !
Academically, you could revert the two woofers into one unit: isobaric load
Not quite nice to perform since one woofer is hidden....and removable panels aren't a good thing. ( there's the possibility of mounting them "kissing" but you lose the mid frequencies )
Finalexam its a two way ,woofers in parallel.
Very little stuffing side walls only.
Best of all the cabinet internal floor is just under woofer so not full length, so really a large standmount!
Yes, fill the whole box with a damping material. Then, if it is a vented box design, squeeze a handful of damping material and put it inside the vent.playing the seventies album rely highlights deficienies, The seventies preferred electric bass sounds more like a double bass!
lack of damping?
I was given a similar design pair of recent Sansuis not long ago; Long story short - the box is too small for the woofers, It performs better with only one woofer, the crossover was a waste of time, the driver connected without the xover performed well as a full ranger, but the high Q means there's still a mid-bass hump. I'll post pics if you want, but don't want to hijack your thread.
Starting point - measure the TSPs of a woofer & sim to see how well it matches the box/tuning
- Anatomy of a budget floorstander
