Hi gurus, recommend me some high voltage transistors for a long tailed pair with supply voltage: +-30-50-60V 😉 🙂
I learned how to design discrete op amp and need test 😀
I tested with 549 and 559.
If I decide to use not so simple LTP I would like to add only two more transistors and here is another quest. Up or Down ?
Current mirror or current source/sink ?
Only one! Which is better ? Any recommendations ?
And how to fight this 0.007% THD 😀
BC546/556 will cover all your voltages.
On the other hand, you can cascode the collectors with some high voltage transistors like 2N5551/5401.
Then, to lower the distortion in this kind of topology, you can:
- add a current mirror (dynamic load for LTP);
- add an emitter follower between LTP and VAS.
current mirror will give you more advantage, then the current source.
2sc1845 is a nice LTP device.
High Vce0
High hFE (rank E & U available). My U are all >600
Medium Vaf
Linear from 1mA to 8mA Ic
Fast above 1.5mA Ic
High Vce0
Medium Vaf
Fast above 1.5mA Ic
Check Q3
It needs a voltage rating that exceeds worst case rail to rail voltage
For a nominal ±60Vdc supply you would need Vce0 >130V
And retain a reasonable Ic at rail voltage.
Tnk u all 🙂
My amp sounds fantastic with an op-amp, lets see now with a pair.
P.S. Paralleling 5532 and 072 is very successful, big synergi. bass from 5532 and highs from 072. i soldered "ic on ic", "ic on top of the other".
P.S.2 vzaichenko, what means to cascode a collector ? Firstly i understood to add a current mirror.
High Vce0
Medium Vaf
Fast above 1.5mA Ic
Agree! Also - low-noise enough
Hey, with current mirror outputs nothing 😕
Aand for newbies -> How to design Discrete Operational Amplifier - Design Guide - Theory - Bart HRK
P.S. oops screenshot error but its the same with the fb connection
why for LTP, complement for output stages 🙂But I don't have any 2sa complements !
You need to add degeneration resistor between the Q3 emitter and the rail, otherwise you don't let your mirror working - it's only 0.7V between the rail and the base of Q3 now.
and use PNP with emitter degen.You need to add degeneration resistor between the Q3 emitter and the rail, otherwise you don't let your mirror working - it's only 0.7V between the rail and the base of Q3 now.
Better if you add EF helper to feed the VAS. See D.Self and many others.
it doesnt work
what do you mean ?and use PNP with emitter degen.
okBetter if you add EF helper to feed the VAS. See D.Self and many others.
Just confirming I bought 1845 but did not buy 2sa992
I wish I had a few.
KSC1845/KSA992 are available from Mouser.
Sajti
An example.
As you can see, with a cascode, your LTP collectors only see the voltage you set with a zener (or some other way) minus 0.7V (cascode's Vbe).
Also note the emitter follower.
just not work 😡@
P.S. look @ this is more powerful
just not work 😡@
P.S. look @ this is more powerfulAn externally hosted image should be here but it was not working when we last tested it.
Now you've got only the emitter follower, but no VAS 😉
- hv transistors for ltp ??
