Amanero Isolator/Reclocker GB
What is the difference between bbb cape from acko and Hermes-BBB/Botic cape? Looking for something to put between bbb and dddac.
Acko BBB cape only provides safe shutdown for BBB. If you wish reclok, master clokc source for BBB and I2S isolation, you need to add Acko reclock AKL-S03.
Hermes provide provides safe shutdown for BBB and I2S isolation. To obtain master clock source for BBB and reclok you nedd to add Cronus board.
You will get the same features with any of them, for the implementation of two channels (stereo). However, Hermes/Cronus allows up to eight channels.
the BBB has no problem working with 45/49 master clk input, if you set the kernel accordingly
now i want full control from bbb to r2r, is it possible to use pins on BBB as a rs232 interface? Ive seen posts in the r2r thread where people were exploring this with arduino.
Can you elaborate a bit more how you set the kernel accordingly ? Are you using Botic-Driver ?
Do I understand correctly that the Config Tool provided by Amanero in their firmware update package (such as the oem_tool_117 zip file) allows one to install/update firmware and the configuration but the tool does not show the existing firmware version and configuration of the connected device?
If so, how does one check the existing firmware versions and configuration on the Amanero device?
Thanks!
I did player using RPi+dam1021 with control over dam1021 by UART from RPi.
Now I star discover BBB. So I'm interesting in your project.
On your picture "BBB_dam1021.jpg" FSEL IN wire is missing (am I right?). Did you use FSEL IN ? Do you use botic driver image?
How did you manage switch between 44.1kHz and 48kHz sampling ? If somebody can confirm that FSEL IN works like is described in dam1021 guide?
I'd be interested Acko
cheers
Thanks Lindamar, I am assuming it is the S04 as shown. This can isolate and sync re-clock up to 2 compatible sources e.g Amanero/WaveIO usb and BBB.
Since you are the first one I will offer the S04 at the price of S03 as soon as the next batch becomes available :)
