Hi Søren,
Thanks!
Power decoupling capacitor, not that critical, any value from 0.1u to 1u, X7R or X5R in 0603 case will do.
Thanks!
luchoh,
I have had similar issue with RPi 2, checking the squeezelite log file showed that it was in fact sampling at a lower than expected sampling rate (48Khz) and because the RPi 2 does not have a lot of horsepower for re-sampling or high quality then one will get the "white noise".
This happened to non DSD material.
Using a PC (more CPU power) with USBtoI2S will yield much better results and >192Khz capability.
Thanks gavinb!
Lucho
I have updated FW to 1.04.
Massive click still occures when changing sample rate. Especially, but not only at switching to 96k; 44k-48k switching is much more silent.
Click appears before new value string appears on the rs-232 interface.
Ulli
Strange... I'm still on 1.03 (it was working with my Amanero since the bug was for SPDIF) and I thought the clicking was notably less (absent except for two situations).
One of the loud clicks happen when you're quickly switching tracks and searching within a track. (quite a rare scenario to be doing this, so I'm not too bothered)
The other is a tad more annoying to users like me who pool some favorite tracks together regardless of albums and set it to random. Pops occur when the tracks switch from DSD to PCM... otherwise I don't hear them on normal usage. That said, there is a small 2-3 secs silence on start of DSD tracks for me.
In my short 2-3 hours of listening time over the weekend, I thought the onboard DSD conversion matched up pretty well to Foobar's SACD plugin up to DSD 256 (Just tested DSD 512 for the fun of it and that had no sound).
When the dam1021 is feed DSD is will display L02M, L05M or L11M, depending on DSD speed.
When no DSD signal and the USB interface is still supplying valid clock, it will display that clock, even if nothing is playing as the dam1021 don't know nothing is being played.... At least that what my DIYINHK USB-I2S interface is doing when the DSD stream is stopped, it keep supplying the clock used when playing DSD....
It turned out that my PC was acting up.. One reboot fixed the issue.
It didn't help that I was doing the testing without actually listening to what the DAM was outputting. Lesson learned..
Boards from next production run will be rev 3 and are now in stock, that batch will only be the 0.02% resistor version
On the EU webshop there is a 0.05% rev 3 version.
Is this, as the 0.02% version, the new design with additional capacitors and two rows of resistors of per ladder side?
Hi all,
two things ....
- First i have done the "16 caps mod" (16 x Nichicon Aluminium Organic Polymer Capacitors 16V 330uF) on a board from the first version. As Rodeodave says: "They are definitely making a difference (subjectively)."
- Second, i found a pic on my HDD which was named as "tl431v5plw_-_100uF-16V.jpg". Can someone say something to this, thanks?!
Ok, found it ... VRef Mod
two things ....
Nice !Another VRef mod, 16 820uF FPCAP polymer caps directly across the ceramic caps. They are definitely making a difference (subjectively).
Objectively too (lower noise floor in ltspice)
For the v1 boards:
official vref mod
lowresmod
Nice !
For the v1 boards:
official vref mod
lowresmod
Is the transistor mod (BC550/560) can co-exists with official vref mod? Or will it be further improved?
@Søren,
another playground with problems.
My third dam1021-05 (sn 000257) with an really old fw (thing was 080) has played without problems and after i updated to 104 it lost the lock each second.
My other updated dam1021-02 (sn 000464) plays as expected without these problems in the same config.
Config: Mac mini - WaveIO (latest FW) - dam
Any hints for me? Can you send me an old fw for testing? Can i do something to locate the problem?
Code:
# set
Conspeed = 115200
Volume = +00
Filter = Linear
Mode = Normal
# filters
04 Bypass FIR1, 384 Ksps
08 Linear Phase FIR2, 384 Ksps, 0-76 Khz -1 db, 192 Khz -100 db
29 DC Blocking IIR, 384 Ksps, 2 Hz HP 1st order
30 Deemphasis IIR, 384 Ksps, 50/15 uS
# exit
L384
L000
L384
L384
L000
L384
L000
L384
L384
L000
L384
L000
L384
L000
L384
L000
L384
L000
L384
L000
L384
L000
L384
It is an improvement to Official mod vref. Two components are removed and put one transistor. Co-exists with 16 cap.Is the transistor mod (BC550/560) can co-exists with official vref mod? Or will it be further improved?
Thanks.
I see from a later post that one resistor has to be short, is that true or I just leave it untouched?
Hi all,
two things ....
Actually, I believe that picture was someone's suggestion to get around the startup issues that some are having after they modify the board where the vref rails aren't rising at the same time.
I actually have to try this mod on one of my boards (which has this issue) so I remember it
@Søren,
Have you a hint for me? # 4611
The privat seller wont take him back because i made a fw upgrade, it / he is so stupid.
Did you try firmware 0.99?
Yes, that is the earliest that i had. It is the same behavior but not so often, think so around all 5 seconds.
I would check your I2S source to make sure the signal getting to the dam1021 is good enough to keep a solid lock on. 384k is asking for a lot if you are using poor interconnects.
I connect AES SPDIF to two dam dacs in parallel running balance mode. I use SPDIF1+ and SPDIF1- and GND as connection. It can lock the signal in normal case, however, when I switch on/off the lights in home such as the lamp in toilet or kitchen, it will loss signal and muted for 1/2 second until it can relock again.
Does anyone know what would be the cause and how to solve it? Thanks.
- Vendor's Bazaar
- Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
