100W Ultimate Fidelity Amplifier
Mr.Miles,
Here is an idea for Fx8 layout. Very compact, but I am not entirely satisfied with number of jumpers. Can you suggest improvements? I have added fuses and bypass caps.🙂. minimum 20mils spacing , dont know if its good enough for iron transfer, but enough for phtoresist.
reg
Prasi
FX8 pcb (based on AX11 pcb)
Hi Mile,
I went out on a limb and figured to add a resistor in series with the 1N4007 for bias adjust. I figured to just use a trimmer there and then replace with a resistor. Please look over my layout and see if things are OK for testing.
Thanks, Terry
Pdf files for AX-20. If any one wants sprint file I can post them.
Hi Mile, do you have layout for other version of FX8 => FX8SCF?
Sonal Kunal
VAS transistors need heatsinks, use BD139/140 instead BC639/640
Mr. Mile,
Here is what I have come up with based on the blue PCB design. changes done
1. added zeners and 1N4148 diodes
2. Zobel
3. rail decoupling caps
4. Trimmer for bias instead of 1n4007
what trimmer value should i use?🙂
reg
Prasi
