I know they aren't NCore, but does anyone know what the data format is for the DSP control software to run the Hypex AS2.100? I have several driver measurements in FRD format, not sure how or if I can convert this. Any help would be appreciated.
I believe I read they take impulse response data, but no idea how to get it formatted correctly for the AS2.
Best,
Erik
Best,
Erik
How do the "real world conditions" differ from measurements? What mechanisms cause what kind of coloration/distortion under the real world conditions? How do you suggest we could measure those effects?
Best to use those calibrated measurement microphones on each side of your head. If they are out of calibration, I wouldn't expect selling too many amps 🙂
I use a Leben preamp (phono 12AT7, line 6CG7) in front of my NC400s. Sounds great and has almost cured me from loving tube poweramp distortion 🙂 Only issue is that I have faar to much gain for my effective Altec 604 speakers and I lose a fair amount of resolution/detail if I use the attenuated output on my Leben....
Yesterday put a very high quality 12AT7 buffer on the input of the NC400, it was very nice indeed. Maybe not accurate, but it worked nicely. I have seen measurements where one stage's spectral distortion was measured and it went through another stage (line stage) and made changes to the same measurement that made it look different but did not actually add distortion in THD terms (already low), which is crazy because it was the line stage that was being measured. Yes, the distortion of the line stage was changed by the input/source. This was done by the late Allen Wright many years ago. So what is accurate? Good question.
But most people have to put a source before the NC400, so it will always be seeing something and people choose sources (and sauces too 🙂) because of what they like, and what they hear too. And that's OK, right? 🙂
Sounds like you need a NC500 based amp and just bypass the buffer. The best buffer is no buffer if you don't need it. I find a straight PCB trace is quite transparent 🙂
Well, as we know, I am just a robot, so fro me it is easy to ensure proper calibration. Too bad that is less easy to do for flesh-and-blood humans. The irony is that the imperfections of the human brain actually creates the illusion of a well calibrated system (despite reality).
OK, how about getting back on topic (hypex ncore, in case nobody remembers any more)?
Yes Ncore, and how the only way it will have a chance of taking over the world is by allowing it to sound like people want it to.
I think ds23man is your friend.
Have you considered lowering the gain of the nc400's by changing or removing R141?
Yes I have. The thing is I dont like fiddling with the surface mount components. I might have to revert to original gain at a later date. bavmikes suggestion of getting a NC500 and bypassing the buffer or use buffer with 0 gain could be an option.Have you considered lowering the gain of the nc400's by changing or removing R141?
Fair enough - the SMD resistor can be a bit fiddly to solder.
Getting a NC500 and bypassing the buffer could be an option or use buffer with 0 gain.
That does sound like a somewhat drastic solution to a simple gain issue.
Yes it is, that why I have lived with the gain issue for some years now 🙂...That does sound like a somewhat drastic solution to a simple gain issue.
Still thinking taking a risk with maybe not being able to restore R141 on your existing nc400's is a smaller step than completely replacing them with nc500's.
Whats the difference between 2xSMPS600 for 2xNC400 modules vs using 1xSMPS1200A400 for driving 2xNC400?
an SMPS600 is the same price as the SMPS1200, is there any reason for the higher cost of the 2xSMPS600 soultion?
This has been covered... but....
The 600 has a secondary supply that allows lower heat dissipation on the NC400 board, where the 1200 lacks this. Beyond that there's not a ton of reason, besides some very slight possible advantages of the dual 600 setup for noise/crosstalk/dynamic performance.
Don't remove just jumper it. Cut the jumper to normalize.Yes I have. The thing is I dont like fiddling with the surface mount components. I might have to revert to original gain at a later date. bavmikes suggestion of getting a NC500 and bypassing the buffer or use buffer with 0 gain could be an option.
Sent from my Nexus 4 using Tapatalk
Good idea troystg!Don't remove just jumper it. Cut the jumper to normalize.
??? what du you suggest jumping?
R141 ( the resistor furthest to the left of the input connector according to the manual)
R141
remove R141 to get infinity resistance and lower gain
short? (jump) R141 to get zero resistance and ?
I use a Leben preamp (phono 12AT7, line 6CG7) in front of my NC400s...Only issue is that I have faar to much gain...
I actually wanted a bit more gain and tried 1K in parallel with R141 and left it like that before I sent the NC400 back to the client today.
I agree with Julf and others, removing R141 is the way to go. I am sure that you could find a competent tech to do it - it is actually even easier to remove an SMD resistor than fitting it back.
Cheers.
PS: Noted the Norsk flag - I have a brother in Kongsvinger. 🙂
- Class D
- Hypex Ncore
