I know that you are using memory for comparison and I'm completely okay with that (but some others, mostly those with bad ears, will look at it suspiciously)
If you can hear the PSU you either have a poorly designed amp are a really bad PSU.
My ears are fine.
Hi
Here you have a very good volumen control, and preamplifi.
Previo inversor - PCPfiles en www.pcpaudio.com
But I prefer to use one with balance. The double pots doesn't work the two channel
equals. And don`t like to invert the signal.
I try this in my last amp:
My ears are fine.
It's not you. You know, there are people who would like to ask for "evidence" anytime you claim to hear difference, as if it is hard for them to accept that everyone has different hearing skill.
Sure (it's subjective). All amps are poorly designed (i.e. no perfect PSRR) and PSUs are not equal. You should ask Apex or hear his comment regarding audible quality of his shunt regulators. The 78xx/78xx are really bad sounding, but you can still see them used in high quality amplifiers (that's because many can't hear the difference).
For those who like to compare sounds, actually I'm interested to hear the difference between Apex's LinerPre with the Tidu. Apex' only have one gain stage (Baxandall), and only one buffer. This might be beneficial in term of sound quality.
The original Preamp PSU Il built as the P05C. It works fine. I recently built the Doug Self Preamp and it was suggested that we use a PSU based on the LM7815/7915 so I made one based on the P05 filters but with the back end circuit based on those regulators. That works fine as well. The PSU furnished with the Self preamp boards also uses the 7815/7915. I am currently trying to get the shunt PSU working but I don't have the transistors in the schematic. I tried substituting KSC1845/A992 for BC639/640 and MJE15030/31 for the BD241/2 but it doesn't work. I may have to order some parts.
An update. The little shunt psu is working. I had a bad zener. First time that has happened to me. It seems to work fine. I will try to hook it up to the little preamp tomorrow and see how it does.
Blessings, Terry
Blessings, Terry
I suggest this PSU for preamps.
I am using this PSU for my preamp.
It has an audible difference in sound quality.🙂
I have 2SK246 and 2SK117BL. Will either of these work in place of BF245A?
Use 2SK246 but pins are different.
Hi
What would be the maximum voltage these PS can be used. For example can I used it 36-0-36V , Also I have another pre amp (UGS) which need 24-0-24V can these PS used with out a big modification...😀
Thank you
Greetings gabor
Hi
Thank you
Greetings gabor
+/-24V can be set without changes, for +/-36V resistor 22k can be change and with 22R resistor output current can be set.
Thank you
Would you please let me know where I can find the layout for the PC board.
Or can you re-posted here
Greetings
Thank you
Greetings
You can find link in post #5919
small mod for easy access to output terminal. any replacement for BF mr. apex?
Use 2SK246 change pins
Note that most have Gate/Base in the middle.
But one must check all small signal transistors to identify where the base/gate is located.
Some manufacturers move the pins around from the norm for that device model. Check the datasheet. And then check the device.
hi hello mr. apex is it possible this AX11 amp power BJT to modified it to mosfet version? i mean if we substitute that BD249C AND BD250C INTO MOSFET WAHT WOULD BE THE MODIFICATION INTO THIS CIRCUIT? i like much of your design you have a great idea in electronics i appreciate all your effort
There is FX8
- 100W Ultimate Fidelity Amplifier
