Pavel Dudek's super Gainclone group buy
Colour of the pcb
  • Black
    Votes: 31 37.8%
  • White
    Votes: 12 14.6%
  • Red
    Votes: 14 17.1%
  • Blue
    Votes: 13 15.9%
  • Yellow
    Votes: 3 3.7%
  • Green
    Votes: 13 15.9%
  • Total voters
    82
Hi peranders, your Private Messages box seems to have overflowed, image attached.
_
Pers-Anders:
I got my boards today.
I have a question regarding the transformers, the spec sheet for the LM4780 calls for 20 to 84V range, what seems to work best for this design?
Thanks,
Patrick
20Vdc and 84Vdc are limits.
For an 8ohms speaker you can use 40Vdc to 78Vdc
For 4ohms speaker you can use 40Vdc to 62Vdc
Both will work below 40Vdc, but I would not recommend the 4780 for such low voltages.
In both cases you must cool the dual channel chip adequately. It is trying to dissipation the waste heat from those two channels through a tiny interface contact area.
