Hiraga Class A30 w amplifier
Dear Saraswat,
Excellent work. Looks like professional fabrication. You have used Dale resistors on the board, who is the seller of Dale resistors in India. I am at Lucknow and unable to get any quality component here. Please share the test results with us.
R.K.Katiyar
Hi, R.K., Dale resistors can be procured online from theaudiocrafts ...but you may not get all values, which was the major reason for series and parallel connection of resistors, as I didn't want to put anything other than dale.it also got me to match the values exactly..so good luck...test results will share shortly...hardware is wip. Regards ss😀
some more pics...
Hi Sergiu,
Initially i went through F5 but pricy+scarce FET's made me look into this amp
1. Can you please share Mouser/Digikey/element14 Manufacturer part# or URL for these transistors
2SA872 used BC258B
2CS 1775A used BC 639
2SA634 used BD237
2SC1096 used BD238
Outputs used 2SC 5200 and 2SA1943
Once i decide which amp i want to build(F5 or Hiraga class a 30 w amplifier) i'll get back with more questions 🙂
Suggestions for Jean Hiraga
For replacement of transistors for Jean Hiraga super 30 schematic is suggested as below.
For input stage transistors use BC 546 and BC556
For driver stage transistors use TIP41C and TIP42C for 90%match or MJE15030 and MJE15031 for 100% match.
For output stage C5200 and A1943 is well ok as these are available easily. Instead of so called original Toshiba, try using CDIL product.
These suggestions are based on circuit simulation performance and making many boards.
K N Dad
Reactions: madhukannan
Hello All,
I hope someone can help troubleshooting my Hiraga 20W amplifier.
One channel dropped out the other day after 40 years.....
There was a negative voltage at the loudspeaker output
I ordered a couple of remplacement output stage: 2SB688/2SD718
After swapping the old output stage transistors (originals from La Maison d'Audiophile) with the new transistors I noticed there is still a negative voltage at the loudspeaker output. I could not balance the idle current properly and the heatsinks did not get warm at all.
So something is wrong. Can somebody give me a pointer of how I can fix this problem?
Thanks in advance,
Hjalmar
