Elektroj I am sorry I haven’t done the sinus test. I devoted the day to my wife’s wish for travelling around some really beautiful places out in the countryside. The weather was so good, that saying no would equate to Dante’s 10th Circle.
George, take your time. Family is more important than some electronic oriented site full of guys with a couple of loose screws (myself included) 🙂
Thanks Esperado and DVV for your inputs.
I am thinking that many here are probably fairly forgetful of what analog masters do have for extended high frequency response. No, it is not perfect, but BETTER than any CD, even with commercial 15 ips recordings.
With 30ips mastering, the response could be as high as 40KHz or more, with a risetime of approximately 10us. I measured it myself.
If you get into the design of the reproduce stage of an analog recorder, you often find a 2pole, slightly resonant filter, at 20KHz or so in commercial models. It was deliberately contoured to fill in the scanning loss of the reproduce tape head to keep the frequency response flat out to 20KHz or more. The actual transient response was much closer to the original than any CD.
However, advanced analog mastering recorders that could make 30ips recordings, would use a different reproduce stage, without the resonant filter ( usually made from an added cap across the reproduce tape head), and achieve a flat frequency response to beyond 40KHz. In any case, virtually all analog recordings made at 15 or 30ips could have a much better HF transient response than any CD. The closest approximation today in digital is either 24/96K or SACD. Just look at the square wave responses of these recordings and compare them to CD. YES, it can be measured, but just listening is usually enough proof.
This is another common issue. DAC playing 21.5kHz sine. Input data are OK, but the DAC filters are unable to make a proper reconstruction of the signal close to Fs/2. The result is modulated signal.
Another "square", 100Hz. But I am afraid that some have not realized yet that any products above Fs/2 in a digitally processed signal are faulty and that they are only creating issues. We cannot directly compare analog squares and digital squares. What is OK with analog is wrong with digital.
Comparing analog (tape) with PCM, the only "advantage" of analog is visual shape of square response. All else is worse (noise, amplitude response flatness, distortion, dynamic range). And the square looks better only visually, in fact it reflects amplitude roll off. Take analog Butterworth maximally flat amplitude filter and you'll get overshoot and ringing as well.
If someone insists on good looking digital square, go SACD DSD.
(1) Just plain outperform the 9600 as a recorder. Better SNR, double the max sample rate, etc. etc.
(2) Do listening tests without bothering with CDs, etc.
And while doing this sort of thing may be new to some, I've been enjoying it since around Y2K. That is what, about 16 years now? Do try to keep up! ;-)
I have zero interest in building a case for keeping CDs except to meet legal and ethical requirements while enjoying the music.
I have had a portable digital recorder that does up to 24/96 recording from phantom powered microphones long enough and used it often enough to have had to replace its lithium cell...
Marsh, you badly misjudge me on many grounds, probably because I'm so far ahead of you with digital audio technology that you can't see where I am! ;-)
I did not mean to indicate you were lacking in some way. just making a point with the 24/96 vs CD. The old ML-9600 work horse has mastered a lot of CD back in its day. Probably many of the CD I have.
I too have portable 24/96 recorders. i too using audio and video streaming. I do video streaming at UHD/3D in Bangkok with 4K. I too have music files on computer and portables. I too have played with 'sound cards' So, I too havent missed too much. Most all of these can out perform a CD. I have a large investment in Blues music.... on CD. Not much of it sounds very good. I have not bought a CD in so long I cant remember when i last bought one..... because of its sound.
Dont worry, I have not assumed what you have done or not.
THx-RNMarsh
Certain filters, maybe. And, certain graphics, indeed. The modulation need not appear in the reality. The issue is the steepness of the filter modelled. Would be the steepness infinitely high, it means the ideal brickwall filter, then the reconstruction would be O.K. Unfortunately, such filter has an infinitely long response (or settling time, if wanted). This is not a problem of implementation, but the "signal mathematics", and it cannot be overcame by any clever implementaton. Nevertheless, the better filter, the better reconstruction. The appropriate oversampling fairly eliminates the "modulation".
THx-RNMarsh
CD's are not mastered that way. They are prepared as digital files set to the mastering facility in a specific format with the table of contents and written to a glass master. The extracted data on a CD may be the same but the creation is done usually with a digital work station (Sonic Solutions was the most popular or so they told me). Early on the files were sent on a Sony Umatic videocassette. Later they may be sent on a CDR and today most likely over the internet. I believe the only "direct to CD' projects ever were done by Reference Recordings and were an incredible PITA to do (the table of contents had to be done before the recording so there was no option to have anything shift in time or pace.
"NOTE: Hyman's solo performances, encoded on the Bösendorfer computer reproducing piano, were played back live for our microphones. For the Direct-to-CD (DCD) editions, the digitized signal was transmitted via microwave to the CD glass master as the music was happening. No recording tape of any kind was used, nor was the digital bitstream corrupted at any stage by copying or editing. The very digits generated at the recording session are engraved on the finished DCD." (I think everyone involved was laughing over the "very digits" line but audiophiles are more inclined to buy if its really hard to do.
It was a very nice recording.
CD's are not mastered that way. They are prepared as digital files sent to the mastering facility in a specific format with the table of contents and written to a glass master. The extracted data on a CD may be the same but the creation is done usually with a digital work station (Sonic Solutions was the most popular or so they told me). .
Thanks for the current update on making CD's. I've read of such for prep for mass production... and DAW are very flexible and powerful tools for editing and finishing before being written to a glass master. The direct to glass is interesting at that period of time.
The files stored on the ML-9600 are those type files. The local burning of a CD allows the person to make a copy of what is going to be heard for small scale distribution. ... like to musicians, producer to get approvals etc. It can also be played back without burning a CD. They could also be sent in file form many ways... over the internet etc. for possible further processing (DAW). But certainly they would not use the machine for mass production of CD's.
Note this is a machine used years ago and no longer in production. The data and CD format (Redbook) is the same for the purposes of finding out what happens to a signal from ADC to CD playback and comparing 16/44 to 24/96 and is the only reason i got it. Now, it is being used for playback only until the newer design OPPO player arrives this week and I test it also. I am looking for the HF noise it may have. I have also looked at the HF of other Cd players and DVD players. No doubt it will have the same roll-off at 10KHz also.
For HD Mastering, no compression and major EQ etc is allowed by those companies I download from. They have their own specs for mastered files to be sent to them. The files are remastered for highest fidelity. A slightly differnt and more direct path to me at 24/96+ are these HD download files from those HD masters. It would be interesting to find out more about HD masterfiles from these internet download sources. Do you know much about it?
THx-RNMarsh
I am sorry, but you did not get it, maybe I was not explaining enough.
1) it is not a result of graphics and it is no simulation. It is an output of sound card digitized with a very fast digitizer. The "modulation" in time domain is another view to twin-tone in frequency domain. The twin-tone is a result of mirror image spectral line, which is 44.1 - 21.5 = 22.6 kHz. This is a result of not enough high steepness of the reconstruction filter. Please check the attached images.
2) everything you wrote about filters is OK, but it is a pure theory. I have measured dozens of CD players and sound cards and I am showing an usual and common behavior of real implementations.
3) it is an Oversampling DAC, quite up to date (AK).
