thank you! I've already prepared 2 olive wood end caps. Much better.If you took the trouble to put some real hardwood end caps on that, you would have a thing of beauty. I like the way you made a decent chassis without a sheet metal bender! Nice work.
Applesauce
This is a first try at putting an amp into a computer case.
The circuit is Kevin Carter's Single SE 6C33C. Dead quiet and sounds very good. That tube has grunt ! I had the amps running open on the boards for close to a year as the standbys before putting in case.
My wife has never said a word about the stream of spaghetti clipped amps that make their brief appearances at the front of the room and to say thanks I figured it was time there was something that looked a little less "adventurous" and with a narrow footprint could go behind the speakers. She was pleased enough with the looks that she told me to leave them in front. I said ok
nice job
My wife has never said a word about the stream of spaghetti clipped amps.
Where do you get one like that !
100% Hand Made Tube Amp
Hi, this is my new Amp, based on Ami Rowe trafos. (R-4359A)
Wood Base is Bolivian "Mara"
Plate is Alu, 3mm
Mod for use 7591A tubes octal instead of 7868 tubes.
Working with my (diy too) Riaa Phono Pre Marantz 7 Clone
A few mods, like the use of 12BH7, 12AX7 and GZ34 Tubes.
25 Watts, 0 hum, very nice to listen.
More Pictures Here
Plate is Alu, 3mm
More Pictures Here
Plate is Alu, 3mm
More Pictures Here
Nice amp! That water faucet would make me nervous. At least it looks like a water faucet on my phone.
Don´t Worry, work with light, not water
Oohhh Yeesss , so good
That is for streaming audio. Very liquid sound!
Yes, I agree the amp is nicely done.
That's nice. You should be an industrial designer!
he he very clever!
Is it dimmable? You know, with the turn of handle...Don´t Worry, work with light, not water
Luxman el tocadisco?
Yes, Dady, is Luxman Pd272, great turntable...
And no, is not dimmable, maybe a good idea to try... thanks The amp or the lamp?
Hello Hectori!
Nice job! Good to see such good handcraft around the Andes.
P.
- Tubes / Valves
- Photo Gallery
