Mini-Synergy Horn Experiment
I've been interested in building a Synergy horn for 3, maybe 4 years now. The SH is what got me interested in high eff speakers, horns/wgs, etc. The more that I build and learn about audio the less I think a Synergy is ideal for home use......the ports near the comp driver exit being my main beef. Thinking and knowing are two different things and so before I write it off completely I figured I might as well build the dang thing. It's not like I haven't had a case of Synergy mids (Celestion TF0410MR) laying around for 3 years or anything :rolleyes:. I've seen some data comparison of ports/vs no mid ports but not quite at the level of detail I'd like to see to make any kind of determination. Some of the best data I've seen is of Paul Spencer's big elliptical job. Looks to be high q resonances in the normalized fr polar, so to my way of thinking what look like off axis resonances are actually mostly present in the 0° curve.
OK........on to the experiment. First I want to say that yes, I do understand that the Synergy horn "should" be a rectangular section and I understand why. My reasoning to go elliptical is 1) I don't see a square section horn as being the ideal shape for the wave, and 2) I have an eoswg just laying around, but no square horns. Elliptical it is. The wg is an EOS job that I built a little over a year ago. 18" wide with a roughly 90x60 pattern, and a 1.5" radius roundover: http://www.diyaudio.com/forums/multi-way/258674-diy-18-elliptical-waveguide.html. The drivers are the aforementioned 4" Celestions and a BMS 4524. I don’t have any pics of the mid chambers at the moment, but they consist of a 2” counterbore frustum that’s .4” deep and a .5” port that’s .35” long. I didn’t intend to make the port that long but my wg was thicker than I remember.The port is offset to the edge of the frustum, and the driver is mounted such that the port is at the edge of the driver over part of the surround. The center of the port is 1.5” from the cd exit which is as close as it can get. My thinking was that 1.5” plus my estimated distance to the phase plug/back plate on the BMS would put the cancellation notch where it would be workable for the xo. I’ve done enough Horn Resp models over the years to know that this would get me close. I’m using 3 mids for this, with the ports spaced equally, wired in series.
Sorry for the lousy smartphone pics. Data is coming next.
My measurement environment in the basement isn’t ideal and a 2.5ms gate is the best I can do with a measurement distance of about 3’. NO eq. First, I measured the wg/hf driver without the ports. Then I added the ports and mid drivers and remeasured with the horn in the same location. I need to do some more measurements and check the vertical and oblique, but this is much better than I expected. The worst of the fr anomalies is at 20° over 10khz, and at 30° and beyond the level seems to fall by 1-1.5dB over the full bandwidth. I don’t know how to explain that, other than maybe the wg itself was shifted a bit to the side from the no port measurement, causing it to be farther from the mic as I went off axis. Need to tighten up my measurements next session.
The first set is the wg/hf driver with no ports, and the second set is with ports and the mid drivers are hooked up to the amp and muted. I've also included sets with angles picked out that show the difference between ports and no ports.
Here's the polars for the hf/mid combo. The xo is acoustically about 6th order at 1.2khz.......I didn't spend a lot of time optimizing it. I took the liberty of extending the gate out to 5ms and adding a 5 cycle freq dependent window to get a little better idea of the low end response. A 300hz hp looks like no problem, even for this small horn. When the hf driver is eq'd flat the levels are nearly matched. I put the horn on a stack of a couple sealed 15's and knocked up a quick xo. I've been in the basement listening in mono all afternoon and it actually sounds quite good as it is. There's something about this speaker that my main rig (which I've been optimizing for a year now) can't quite do.....and this is just a rough prototype! I was worried that pushing this little cd that low would be pretty bad but it's actually holding up quite well even at higher spl.
The whole point of this experiment was to see the effect on the hf response of the mid ports to see if it's worth building a larger set for my main system. Going in I was quite skeptical and I've built enough junk to not have any pride in saying it didn't work out. That said things are looking good so far.....
Hi Nate,
Is the idea to improve the waveguides ability to go lower in frequency to a lower crossover point? But then how do you match the woofer directivity to that of the waveguide? And won't even a waveguide that size loose control below say 700 Hz.?
The ports made far less effect than I would expect as well, but then they are very small. You probably can't do good polars for the mids in your situation right? I would be very interested in seeing those.
PS. I'd love to plot those in my PolarMap program. You've sent me data before right?
Neat!
Here's some things to try to take it to "the next level."
1) get HolmImpulse or Arta so you can measure phase
2) Measure the distance from the throat to the midrange taps. Now set the lowpass on the midranges to achieve an acoustic lowpass that's about 3rd or 4th order. The idea is to introduce a delay that's enough to keep the midranges from radiating until the tweeter "catches up"
3) Then start tweaking the lowpass slope and the low pass frequency until the phase 'snaps into' place
Basically if you juggle the xover slopes, the midrange distance, etc, you can get the phase and frequency to behave like it's a single driver. Be sure NOT to flip the polarity of the tweeter. You probably want to double check the impulse of the drivers to insure that they're labeled correctly too. (Occasionally you'll find that drivers labeled for positive polarity aren't.)
It's really easy to get the response flat, the key is to get the phase right :)
Once you do that, it's really eerie, the speakers seem to disappear.
Founder of XSA-Labs
Joined 2012
Nice work! You sort of made yourself a Red Spade PSE144. Cool that you are noticing something about it that sounds better than your main rig. It's the controlled directivity of 400Hz on up from a point source. There is less splash from walls and other surfaces so SNR is higher. The sensitivity is high so the distortion is low. I remember the first time I made one and listened. It's a stunning sound - can't stop listening.
Red Spade Audio PSE-144
Earl - the idea here was to test the effect of the mid ports on the hf response with a wg I already have built. If/when I build a wg specifically for a Synergy horn it will be large enough to maintain directivity to about 300hz where it will hand off to a couple of side by side 15s. That said, I was surprised to see that this wg is still at almost 90° at 500hz. The resolution isn't there at 500hz of course, but I've done enough comparison of outdoor vs indoor data and I've found that at least the rough polar is accurate....even if the details are obscured.
I have sent you data in the past, but that was an outdoor measurement session with a speaker hanging off the back of my deck. Outdoor measurement season has ended in Minnesota :rolleyes:. You need about 6ms of clean impulse for your sw, right? The best I can do - when I have my living room cleared out - is about 4ms at a 4' distance. If that's workable for you I'll see about doing that in the next month or so.
Patrick - I can measure phase just fine with a dual channel measurement in REW. However, it's my understanding that you need a fair amount of overlap between the hf and mid to get a linear phase xo (without resorting to FIR filtering). As it is I've got maybe 100 or 200 hz overlap before I hp the compression driver.
I have some ideas about making the effect of the ports even less, and some tests of this new configuration on a flat baffle have shown to have the effect of extending the mid response a bit. I'm going to try that at some point to see how it works out. I've also got some foam throat plugs cut for this wg that I'll try and see if that lessens the effect.
xrk - Seems Paul and I are on a similar path.........he just made one first! I've been thinking about an EOS Synergy for a long time but now I have the ability to make it happen. FWIW my main rig is a high eff job with about a 120° pattern down to 300hz so it's no slouch.
Using three mid drivers is a bit odd as far as wiring goes. I've got them wired in series now because I doubt the test amp I'm using is stable under 2ohms. My main amps are Hypex uCd180 and I'm told by an engineer there that it will be stable under 2ohms. We'll see when I get there!
A sperical sector is fine having a square cross section, the issue is the round cone. It can be done.
I don't follow........are you assuming we're driving it with a spherical source and the transition from round to square is the issue? Or that we have a plane wave source (more or less) and we need to transition it to spherical? The latter is my understanding of the purpose of the OS profile. To do the transition as quickly as possible with low diffraction from plane to spherical. I think Earl's phase plug patent covered the transition to a square section.
This is one area (of many!) where my understanding is rudimentary at best ;)
Joined 2008
Nate, where all paths along the walls represent a radius of a sphere where at the centre is a point source, the waves can propagate along them regardless of the cross section that the combined radii form.
Of course horns have other means of action. In some respects square or rectangular has advantages.
I am with Nate that the round device is a better match to the compression driver. A square throat with a round CD on it is not ideal. You could go from round to rectangle if done slowly, just like round to elliptical - just nothing abrupt.
Nate - my software can handle any free field time, but of course, as with any software the more time you have the better the LF data will be. But in this case we are not so interested in the LF data anyways.
I am quite interested in the phase response of this design. Of course any design can have flat phase with some DSP added, but it is nice to have it inherently flat.
Earl - I know we've spoken about this before but just to be clear with my PC setup and the way I have to process audio I cannot get time-lock to work in Holm. You have data posted in your sw of a speaker of mine that was done with no time lock. That is how you would get the data.
I'm not "there" yet with the phase. I had something quite close to linear phase through the xo last night but it required that the compression driver run lower than I wanted to. I'm working on some changes to the mid port/chambers that will hopefully extend mid response and give me a little more room to work with. Of course it would be easy to just do an FIR correction, and the cool thing about the Synergy is it should hold up over all angles.
If the time base does not move too much it can be all right, but if it moves a lot then problems will ensue. Send me some data and I'll see what I get.
I only recently started to look at phase in my speakers and I was pleasantly surprised that it was fairly well controlled without doing anything special. Over the bandwidth of 700 - 7000 Hz - the critical range for phase - it varies less than 60 degrees. That's pretty good considering it just happened that way. I have always been conscious of a compact impulse response and the phase shift has to be minimal for that to occur, so perhaps I was forcing a flat phase without even doing it deliberately.
Neat!
The band pass mids are acoustically delayed from the HF, and may not require any delay, the opposite may be true.
The HF is physically further from mic but measures .62 millesecond closer in my SynTripP.
The screen shot below shows the combined raw response of the (ported, Fb 81 Hz) cone drivers and the HF driver, note how smooth the phase response is with no delay applied.
Using two diaphragms on a single horn is not so new, BMS has been doing this for a long time (also see Adamson). In those designs it is always easy to find the crossover point between the two diaphragms in both the FR and the polar response - its never ideal. Perhaps it is the very low frequency of the crossover in the synergy that helps this problem.
Joined 2008
The blending I saw was uncanny. If Akabak wasn't an arbitrary simulator I'd have assumed there was a mistake somewhere.
Not sure I follow. The designs I was reading about at the time were using the mids to cover the octave below 1500Hz and I didn't see the point in doing that, especially with the assumed disadvantages.
I wouldn't be keen on a design that wrapped the throat around coaxial cones.
I made some changes to the port configuration which I'll detail later. For now here's a new xo I worked up. Acoustically it's at about 1.2khz. It could use some more work but not bad really! I don't have as much overlap on the hf and mr that I thought I'd need but I think that phase looks pretty good for a first crack. Didn't take me long to arrive at that.
I also have some open cell throat plugs made for this wg that I use in my main system. My hope was that the foam might "clean up" some of the reflections from the ports (not that I'm seeing much in the way of reflections) due to the longer distance traveled through the foam vs the main wave. Measurements out to 70° didn't show any change other than the normal attenuation.
I just might drag this thing outside this weekend for some better measurements. Sunday looks like 40's with little to no wind.
