What is the steepest realistic audio transient in terms of V/us?
You know, I have been designing solid state power amplifiers for almost 50 years, and I find many here with a lot less experience than me, and therefore prone to make the same errors that I had made up to about 45 years ago. It's time to catch up with what modern designers know. We make amps with 50V/us or more, if at all possible. Rise time is usually 5us or less. Heck, I made a famous power amp design more than 45 years ago with 100V/us slew rate with 4MHz f(t) transistors. I have never looked back to the early days of 10-20V/us for the last 45 years since either, because my faster designs, as well as those from Matti Otala, just sounded better than anything slower, that was available at the time and probably even today.
You just can't sit in an armchair and decide that slew rate is unimportant, or that a rise time of 10us isn't possible in the real world. I think we call that sort of thing 'sophomoric'.
Just to clarify. You're not saying that you've been recycling the same design for 45 years?
Question for Mr. Curl...
John, I deeply respect the innovations and designs you've added to the opus of quality, fresh innovation in audio engineering in the last 40+ years. I have three questions which have been bugging me for decades.
ONE - in relation to a comment earlier in this thread: “I had no amplifiers below 100 watts [per channel]” (paraphrased). … I'm almost certain you imply “for 8 Ω load”, which in turn requires at least √( 100 W × 8 Ω ÷ 2 RMS factor ) or 20 VRMS which only for sines would be 28.3 peak volts. The question is, what level of overvoltage headroom do you design in?
I know this is a question fraught with side analysis. Nature and content of the music. Degree of 'headroom' built into the recordings. And I'm almost sure that you've addressed this elsewhere, but it is hard to find. Keeping it simple, do you design for 50% peak-before-clipping voltage headroom? 100%? 150%?, since all amplifiers must have some upper limit before clipping.
TWO - Is it the case that a “100W with 250W dynamic output capacity” amplifier also having (say) 50 V/μs performance, has better performance at more modest (and yes, let's call it “musical”) levels? The question reflects on my personal mmm… theory or analysis or something between: played at more modest levels, all amplifiers (short the miracle few) perform more accurately, having to fight a whole lot less speaker-motor reverse EMF, than at the highest levels.
THREE - Is not one of the most important design criteria (which is admittedly very hard to numerically resolve), the matching of the damping factor (servo-like output voltage tracking viz a vis input signal) of an otherwise competent amplifier to the intended set of speakers? Again, perhaps a personal theory or predilection, but it seems to me (from physics of second and third order derivatives and oscillatory/energy-storing systems) that there must be a critically important tracking-factor that both “leads” the speaker cone excursions, and that also “binds” the speakers to the evolving signal.
Humbly, I look forward to your response.
GoatGuy
How would you define optimum value of "damping factor"?
Forget "Damping Factor"
Look instead at the total impedance feeding the speaker and determine whether that speaker requires less, or the same, or more impedance to operate as you need.
In my biased view of advertising script writers, I think they invented that phrase to impress the gullible buyer.
eg.
"Our 1000 Damping Factor amplifier is far better than all our competing Manufacturers' Damping Factor of only 500"
Completely useless nonsense.
AVA amplifiers with infinite slew
Last year I was about to buy a Frank Van Alstine hybrid amplifier with Exicon Lateral MOSFET: Fet Valve 400R
avahifi.com Power Amplifier Buying Guide
AVA amps are super fast they have infinite slew factors (confirmed by the late Leonard Feldman in an Audio magazine review reprint online at www.avahifi.com). The clarity and detail you hear with an AVA amplifier is so pleasing because we provide the bandwidth reserves to pass all the music unaltered. They are kind to your tweeters and to your ears. The definition and transparency are clearer than ever, providing effortlessly liquid and extended highs.
AVA amplifiers are DC-stable so lows cannot overshoot and boom. They have no turn-on or turn-off pulses under normal conditions. They are kind to your woofers because they reproduce musical bass, never dumping DC or excess rumble into the system. AVA amps (except the Ultimate 70) have full complimentary power MOSFET output stages so rugged and carefully designed that no dynamics-stifling current limiting or protection circuits are needed...
By the way, the amplifier bandwith of Fet 400R/600R is about 350 kHz.
Fet Valve 200R, Why not, Frank? by maty
-> Fet Valve 200R, Why not, Frank?
I suppose (and everyone) "infinite" = very high
Very fast -> slew rate very high and rise time very low
Job, Goldmund and others use Exicon lateral MOSFET too. Better with double die => not problem with any impedance (8, 4, 2).
JOB Products
The JOb 225: (maty: better with > 4 Ohms because is not double die)
SPEED
  • Slew rate : > 60 V/us.
  • Rise time : < 200 ns.
The JOB 250 (mono):
SPEED
  • Slew rate unloaded > 80 V/us.
Hi-End Class A-AB Hybrid Amplifier - the reference with "incredible slew-rate"
Allow me a small digression:
Hybrid Amplifier by Andrea Ciuffoli
The Spice simulation show an incredible slew-rate (20V in 200ns) because the mosfet are driven with a tube with a low internal resistance (near to 2Kohm) and an interstage transformer with a turn ratio 2:1 reduce it (4 times) this value (2Kohm / 4 = 500ohm) (here the .cir).
MOSFET
In my test 2SK1058 (Hitachi/Renesas) and ECX10N20R are much better than BUZ900P (Magnatec) as distortion value but the ECX10N20R (Exicon) are better than 2SK1058 because have the same distortion value but a better damping factor.
The minimum distortion with BUZ900P is at the bias point 30V DC and 900mA at any output level.
Using the 2SK1058 and the ECX10N20R the minimum distortion is at the bias point 30V DC and 1600mA and the THD level is 60-70% less than BUZ with the same input stage.
If we increase the power supply to 40 or 45VDC the ECX10N20R show a limit and for all the best bias point is 1000mA.
The 2SK1058 and the ACD100NSD have the same distortion and the same wide voltage range to get high power output.
You cannot use IRF types and 2SK1529 in this project because these need a thermal compensation circuit.
In the simulation the output impedance is about 630mohm on all the frequency range with the mosfet ECX10N20R and about 1 ohm using the 2SK1058 and ECX10N20R...
