UCD 25 watts to 1200 watts using 2 mosfets
Good PCB,Only single mistake ;)
MANOJ
Hi Juan,
Power AUD600, Don't need 2K/5W & Z12V.DC protect(relay) work on same Bias Supply, and you are not provided AC fail ckt. see rev.3.0.1 schema, also see Relay contact points(C,NC & NO) on ckt.
MANOJ
I just begin the other day sir the PCB is going to be changed some components, that is why I say is not completed :) I will fallow the rev 3.0.1 schema, and yes I notice that 2K/5W is not needed ;) I will post later in a few day I have to "brainstorm a lot now" :D
Juan
hello manoj can you give a example of a bifilar winding ? I made two macros one to flat surface and one upright mounting also, I read on schematic that relay need to have a 30A contract type is this relay type will be ok to use ?
Juan
Hi All, few years ago I made UCD, but I changed feedback network a little.
Are there any feedback network changes here? To improve THD rating even better.
Also I would like that someone write down subjective "hearing" opinion, comparing class AB (high quality AB class amplifier) with UCD, using same speakers, same "music".
Hello gentlemen
I spend a couple of hours yesterday on the AUD600 power supply board and I made a few changes the capacitor now larger ones can be use up to 35 mm in diameter at the moment of this writing, also I decide to change the bridge rectifier to one that can handle more current up to 600V 50A "actually I'm fallowing mister manoj schematic", part number MP506W-BP I change the relay to a one that can withstand more current on the contacts 30A part number JTN1AS-PA-F-DC12V.
mister manoj let me know if this relay I can used for the circuit
I still working on it this and it still a draft not a completed PCB yet but I will post a couple of time as I go good day guys :)
Best Regards
Juanhttp://www.diyaudio.com//www.pinterest.com/pin/create/extension/
  • MP5005W-MP5010W(MP-50W)-477808.pdf
Hi Juan,
Nice work.Your PCB size is little big (190x100 mm).
You can add HOPS and UV/OV ckt on this PCB(Full protection)
MANOJ
thank you :) and yes it is way too big I will try to reduce if I can:) yesterday I was simulated the circuit protection and respond really well to dc detect amp failing and transformer activation "if transformer is off it will shot down" or make relay off but I notice relay activate way too fast or maybe is the software that is doing that ? is there a component value that can be change to slow down the relay delay time delay activation ? maybe 10 seconds perhaps ?
Best Regards
  • AUD600 power supply.pdf
I most have done something wrong, :confused: on pin one bias I have -63V and pin 3 (-) is -75V
I found the info in post #3134
so pin one need to be +12 right ? :) maybe is better if I use a separate 12V regulator and add a small bridged rectifier for the 12V IC regulator to use a separate small transformer or from the same toroid
  • AUD600 power supply pin one wrong bias voltages.pdf
Hi Juan,
Yes the voltage what you get is correct if you measured with respect to GND
BIAS PIN 1 is +12V with respect to -HV Supply rail (BIAS PIN 3)
MANOJ
oh wow ! so is good to go nice ... :D I do have approximately 11.7V :) nice so I can continue then the PCB layout at least I know DC detect and 3 sec delay is working good too :nod:
Best Regards
Juan
Hello mister manoj I have a little problem, the LED does not light up at any circumstance on the simulation ? what could be the reason ?
all the circuit responds really well I have 12V on pin 1 (+) and DC detect works well if detect 4V it will release the relay NC and also the transformer detection also works too :)
but not the LED ? :confused:
here how the layout looks now today I know is too big but maybe with time I will reduce size is possible as I go day by day
  • AUD600 power supply LED no responding.pdf
