Analog audio millivoltmeter
If it is any interesting for a simple audio millivoltmeter.
This was published in Elektor magazine ( year1991)
It's all greek to me 😉
While it could be fun to build something like this you can do a lot better most likely by purchasing something like a secondhand:
HP 3468A
Fluke 8050A
If you know where to look, functional ones can be had for less than US$50.
Here is the schematic diagram and specifications
Thanks 🙂
Not to make it literally but to adapt the basic idea (specially the input attenuator and audio rectifier) using a couple Op Amps.
It can be easily done with a couple TL072 😀
Main problem and most expensive part is getting the proper 50uA meter, the rest is easy.
Just please translate and post any adjustment/calibration procedure 🙂
I guess the switchable 100r and 324r resistors chance scale from multiples of 2 to multiples of 6 ?
As of the schematic, I didn't understand a word !!!!!!!
It's in ...... German !!!!!!!!! 😱
HP 3468A
Fluke 8050A
Agree we can buy everything,but what we doing here in a diy site?🙂
I see many fluke 8050A ebay sellers but all from USA.
The input adjustable attenuator uses Capacitors in parallel to the resistors.
Why?
Is this to use a capacitive divider ladder to compensate for unknown parasitic capacitances that we know must exist?
I like the 12r||150r for the bottom step to give the required 11r1111 repeating to ensure the bottom step achieves the necessary -20dB attenuation and all the steps give the 20dB increments.
Why?
What about just building the attenuator and amplifier upto and including C20||C21 and using that as a pre-amp to feed an rms reading DMM?
Is S2 a gain set switch?
1)Capacitors in parallel to resistors used for compensation .In that way attenuator remain linear for frequencies greater than 500 kHz.
2)You can't do that.T7,T8 is a part of active rectifier.You need an A.C audio voltmeter to measure on C20//C21.
3)Yes S2 is a gain set switch.When S2 is in position 1 gain is 83 and when is in position 2 gain is 26.
I did say rms reading DMM.
Of my 4 DMM only one is rms reading and it goes to somewhere in excess of 1MHz.
And my oldest average reading DMM goes past 20kHz with some response errors. By 50kHz it is well down.
The meterless pre-amp could also feed a scope.
Is the gain, using that S2 switch, giving +28.4dB and +38.4dB?
Yes that is what i see...$50 shipping cost🙁
...and then you get whacked with VAT at customs.
I have an HP403 meter which wasn't working although the attenuator and meter movement were in fine shape. It's an early transistor model which uses "positive feedback" to obtain high input impedance. I replaced most of the circuitry with discretes and added a Linear Tech true RMS detector.
It's nice to have an analog meter rather than digital display!
