Yes, it's planned to send out deliveries soon, we are gathering the materials to produce first 200 pcs. next week. Stay in touch, regards L.C.
L & S versions PCB-s designed (L: 50 x 160 mm, S: 50 x 60 mm), few test modules available in two weeks, just to be sure they're fully operational. As planned L & S series will be send to production latest at the end of November.
HI LC,
The input voltage will by the same as FO 1.2?
Voltage gain is the same: 24,4*Vin ie. +27,75 dB
Great news, had you find space on S versions 50 x 60mm PCB for a 2,2/4,7mF German powerhouse 😛
Teezer
LC popped by yesterday with the finalized version of the First one 1.4. Mine version works on 43 Volt version of the hypex power supply. It serves as a testbed for the VSSA replacement, the First One S.
While waiting for the propper enclosure (Black mamba with VU meters) I have it setup the same as the last years 1.2. On the board with the heatsinks.
What can I say about the sound. So far complete neutrality. It keeps composure of the recording no matter what. The way it drives my Thiel speakers in the bass department is ... just have to listen and verify for yourself.
I have to be careful now because my foot is tapping so much and too often. Not to injure myself. Or make a hole on the floor 😀.
Do I have to go to work today? Or have to listen more?
As far as I'm concern for now SMPS1200A180, 400 and 700 are highly recommended. They have soft start, 115/230 V mains selector, auxilary voltages +/-12 V regulated, shutdown function and they're very reliable. Warranty works - in a case of a falure you get new SMPS.
Power supply and dimensions:
First One S: 50 x 60 mm, +/-40-63 V (SMPS1200A180 or SMPS1200A400)
First One M: 50 x 100 mm, +/-40-63 V (SMPS1200A180 or SMPS1200A400)
First One L: 50 x 160 mm, +/-50-85 V (SMPS1200A400 or SMPS1200A700)
If someone find better SMPS for the price/performance please take a try.
Regards, L.C.
Regards, L.C.
hi Lazy cat,
I know you are probably busy trying to get the product ready for shipment.
But please do post detailed spec, measurements, graphs for FO1.4 when you get a chance
Very wise decision, upgrade to v1.4 will transfer you to another world, guaranteed. Silence here doesn't mean nothing's happening behind the scenes, on contrary, latest eight modules from the test series above, have been molested, beaten to death, but surprisingly all survived and passed the test period successfully. So I guess now's the time to start the real series as befits.
Mmmmh "beaten to death", "but surprisingly all survived" that does sound a bit Biblical to me.... But having listening to my V1.3 with great pleasure and thereby I have "faith" in your skills Lazycat. So I do "believe" it is possible that the V1.4 could be even better than the V1.3...
I wonder If it helps to have "faith" in the Lottery...so I can buy Lots of them...
R.
Is it possible?!
First One v1.3 doesn't stand a chance against v1.4, both in a different league.
Up to now probably it was not clear enough, v1.3 & v1.4 topologies are diametrically opposite, totally different stuff, v1.3 concept rely on simplicity, topology consist of all together 8 transistors, on contrary v1.4 is based on complex CFA topology made out of 26 transistors, lots of CCS, IC, etc. all together almost 40 semiconductors located on both sides of PCB. I had much more work to do to "convince" the electronic parts to cooperate to represent the music in a way not heard before. What that means in reality I won't explain with words, rather will be reserved as an opinion gathered from each other's experiences, published here later in the process.
Well technical I really qualify as "Noob" and have to rely on the experts. But even then "the real life experience" could be very different for each of us.
So I appreciate it when (my) "Experts" write "What that means in reality I won't explain with words". This together with my personal V1.3 experience makes me more then curious about the V1.4 and leave the experience with me". So, only 1 thing remains.. having some luck in the Lottery.
R.
R.
Why Lotto? The price is the same as it was, 88 EUR for the module, that's less than engineer's service hour in developed western countries.So, only 1 thing remains.. having some luck in the Lottery.
R.
New First One M modules inside black C1 chassis.
These chassis look nice! Where can I get those?
Also, I keep reading about "DC sense": what's that?
(Sorry if the answers are in the thread, but it's too much to read everything in detail...)
Don't worry. I have 2 FO1.2 and 2 FO1.4. I don't wish to go back. FO 1.4 is really fantastic.Well technical I really qualify as "Noob" and have to rely on the experts. But even then "the real life experience" could be very different for each of us.
R.
I was able to listen to all 1.4 prototypes and it was really a long way and lots of work from LC. The last one goes to the way of really high level of neutrality and transparency. It plays all the little details, I can hear new stuff all the time in all the albums. This is especially welcome in classical music recordings. It makes more sense.
Since 1.4 and 1.2/1.3 are so different. 1.2/1.3 give you a nice feeling of what LC was able to get from simple design. Some of the 1.4 developments could be implemented in 1.2/1.3 without increasing complexity of the PCB. I don't think it will happen though.
About the lottery. Just buy 2. It will be enough or wait for the S. I believe that one will be for the audio purists.
Local machinery produce this C1 black chassis (Black Mamba) in accordance to my orders placed, backed up with some real currency behind. It's perfect match for First One S, M or L modules in dual mono, together with two SMPS1200 power supplies.
DC sense is a passive DC detector PCB located at speaker's terminals, connected to SMPS1200. In a case of DC failure it shutsdown SMPS preventing speakers from disastrous moments.
- Vendor's Bazaar
- First One - mosFET amplifier module
