Unique CFA 120/230W amp
I run the last sch file and q5 / q7 was about 250mW still not excess the limit of 300mW so it is ok. But these are some changes in component values of:
C9, C10, R43, R54, C14, C5
since I already order these items based on old value, I will try with old values first.
For better overload behavior R55, R56 added.
After a lot of great help from topic owner, I manage to create a PCB layout of the amp. I'm going to double check it and so some fine tunning until it hit the PCB company. Comments are welcome!
- Could I use BC560C/BC550C in Q25, Q26 because in sim, VCE ~ 26V ?
At this place BC546/556 are better performance wise, a least in my simulations of enhanced "VAS", look like beta matter less than high VCE as this transistor doesnt load the previous stage significantly compared to R2/R5.
Also their collectors should be decoupled in respect of the rail voltage to suppress the miller effect due to high values for R20/R24, at lower values decoupling is not needed.
I think I can:
- Set R43 = 300, C9=C10 = 220p, R54=47, C14=C15=22p. How do you think about this change? It is mainly because I already ordered the mica caps when I followed this schematic http://www.diyaudio.com/forums/solid-state/253039-unique-cfa-120-230w-amp-15.html#post4362435.
You an use the caps you have but for R43 use 220R, you will get phase margin somewhat lower.
BC560C/BC550C is not good enough. In case of clipping whole voltage will be between collector - emitter, 45V is max for those transistors.
I don't know from which schematic R20/R4 are coming, but if you mean R49/R50, I simulated decupled collectors and THD20k at 100W/8 drops from 2.03 ppm to 1.99 ppm. I think it's not big enough gain so I did not use decoupling there.
It was in one of your previous pic with the values at 15K, i simulated again your amp and it s right that they do not have a big influence in this design.
R27/c6 and R28/C7 provide HF isolation between the pre-driver and driver stages. If you layout is very good (short low inductance tracks etc) you can possibly get away without these devices. If the track inductances are high, the pre-driver and driver can form a Colpitts oscillator structure and you get instability. I did a lot of testing on my e-amp (EF3 OPS) on this subject and concluded this network gave important benefits.
