SlewMaster Builds
JW,
Thanks I wasn't considering all the different output devices. At the same time could you have a couple or so, for each type in a 5pairs configuration that could then be used for everything? Just label them by output device type and not have to keep making more variations due to number of outputs?
Jethari,
What are the actual physical dimensions of your boards? I would be interested at some point in your boards or the actual design after you get around to them. That looks very nice and does away with the extra length of the 5 pairs boards for those of use not needing the last two pairs. I also have a limitation in width that I can use and this looks perfect for that. I would however be mounting the board in a vertical orientation.
Steven
Jethari,
Steven
Steven, the dimensions are 3.2" X 8.5". I'm waiting for others to go through the layout and make necessary corrections after which I can upload the individual layer files (pdf/gerber/eagle).
Hari
One channel almost ready except for the inductor
Do you see any errors?
