DC Servo MOSFET Amplifier
I like this amp so I went ahead and built another F100 PSU/protection board too. Here is a pic of them hooked together.
This is a nice amp. I running it now on +-60vdc. It is very powerful so such a small footprint. I have to clamp a heatsink to that angle of course. One note, for those who may want to build this. The trimmer has only two holes so the center pin must be bent and soldered to one of the other pins before being fitted to the board in place of the 4k7. As I said earlier, 4k7 is not enough to bias the amp. It needs at least 3k. I am running them at 2k7 and I will probably replace the trimmer with a 2k7 resistor just to be safe.
Blessings, Terry
For those who want to mount the outputs vertically here is a layout for that.
Also, I'm not sure if Thimios is still building APEX amps but just in case I am attaching a photo sense file too.
Blessings, Terry
