Krell KSA 50 PCB
hi i have been building a ksa 50 and having some troubles with the power supply i am using 500va 50 0 50 toroidal transformer with 470000uf 63v capactitor iv been using a diagram found on google images but i keep getting 140v across across the plus and minus rails would anyone have a better idea i am a little stumped.😱
guys im planning on using a 40 0 40 transformer, i simulated the circuit on multism i can share it for everyone, assorting to the simulation the VI outputs increases THD and keeping them away and increasing the voltage to 50VDC gives me 67w and a extreme low THD
whats your expirience?
regards wolfintosh
The KSA50 clone described in this thread uses 37-0-37 DC rails. Heat dissipation requires immense passive heat sinks or sinks that are fan cooled with all the issues of fan noise.
I constructed this amplifier but used 25-0-25 DC rails, dissipating about 70watts per channel in heat,this gave an amp that had a reasonable physical size with passive cooling, although still quite a heavy lump to move.
Very pleased with the result.
Bear in mind what is continually said about Class A ---- never underestimate the amount of cooling required.
Alan
the KSA100 used a 37Vac dual secondary.
The KSA50 came in at least 2 versions, one as far as I remember used a higher voltage transformer than the normal KSA50. Both had a lower voltage than the KSA100.
a dual 25Vac transformer would make a good KSA50 clone.
a dual 30Vac transformer will make a hot KSA50 clone.
a dual 35Vac transformer will probably blow up a KSA50 clone.
No body thinks about using a dual 40Vac for any KSA50 clone.
70v its ok for that transformer because its your rectified voltage 50*1.4=70 but for the ska 50 and that voltage check all transistor support if and also you will need more output drivers if not use a zener diode to reduce and regulate voltage
You have a very serious problem or mistake somewhere. Double check everything and remove semi's from the board and test them all. Also test output devices. 30 volt rails is a reasonable DC voltage on this amplifier and shouldn't cause any headaches. When you get it working again use a variable to slowly bring it up and also a scope to be sure the amplifier is not self oscillating. KSA-50 is an extremely simple, stable reliable circuit. Mine is now 9 years old...
Thanks Mark, ill check it again i tested with multimeter an seems that one of the masa transistor is the one that got broken, im thinking about oscilation because it failed after i played a 20hz reference tone, with music worked for hours
Wolfintosh, I presume you mean one of the 100ohm emitter resistors for the pre-driver transistors ? What was the total bias per rail you were using with 30V rails ? What circuit are you using-- the Delta Audio from the start of this thread ? What load were you driving into ?
Alan
Alan
thats correct, the bias pot i have it adjusted almost halfway at normal bias a 5k pot, im using the delta audio version , my goal its to run it with 42v rails it is been tested with my lab power supply, i replaced the masa transistors and some 2240 and 970 the ones that are placed almost together and it worked again, i want to tweet it and prevent this, also i made measurments with the scope at school an the signal look perfect without load, it an 8 ohm load with that i get a bit of distortion on politeve cycles of the sinusoidal wave produced by the function generator
hey guys having a huge doubt, I've been looking for a transformer in my country has been a headache, currently I've been testing it with my lab power supply which gives me +-32VDC but i own a transformer from an old sony amp 100WPC supposedly I've measure it and gives me 60VDC rectified could i use this DC voyage with Jan Dupont PCB????
or i should regulate the voltage to 42v my heatsinks are massive 4 inch tall 16 long per transistor row 2 heatsinks and i will add temp control
I am posting this here as well as in the for sale threads...
Have been going through old parts and stuff this past week and ran across a few 2nd Generation boards I had made way back when this long running thread switched boards. These boards were made way back when the prototype boards were made except I had them gold plated with black stencil laytou for the parts. They look very sharp. I also had a dozen KSA-100 boards done the same way but I only have two of those left now and am going to hold on to them.
I have five (5) sets of the boards shown in the attached pictures if anyone is interested. I am not giving them away, I need to get $40 USD per set for them. I likely paid more than that for them when the prototypes were originally made because I only had 16 boards made and only a Dozen were gold plated.
When these are gone that's the last of my KSA-50 stuff from when this thread began.
Mark
https://www.flickr.com/photos/56008415@N03/22241088783/in/dateposted-public/
