http://www.vinylengine.com/images/forum/stylus_shapes/FG_stylus_with_ruby_cantileverErnie.jpg
This is glued on ruby, so i assume with boron the same. It seems to be more glue than expected.
Boron is used because its harder than aluminium, giving different damping properties.
Not always ? http://i170.photobucket.com/albums/u252/fftulip/audio/Dyn30B_sty.jpg ;-)This is glued on ruby, so i assume with boron the same. It seems to be more glue than expected.
Yes, but the 30 B has a solid boron rod, no tube. ( some say ist beryllium, but most sources say boron)
Today laser drilling is possible, whatever material, but with alu you can press fit due softness, then adjust the diamond and then glue, minimal amount, boron is very hard (9,3 Mohs), density is nearly like alu, so there i see no advantage for solid boron, its more mass than a tube.
A never ending story
Yes, cartridge/ tonearm matching is important. If the resonance is strong, it amplifies the distorsions created due mistracking, misalignment and so on.
The tip creates small distorsions, depending on shape, velocity, angles, lenght of cantilver and so on. The angles maybe reach 1 Degree at max. modulation if we assume the record is flat and not excentric. This is not audible as distorsion, it partially defines the *Sound* of the cartridge.
But if the arm/cart resonance is strong and the record is not flat and excentric, this angle gets bigger. If you can see the arm shaking, it is possible that the cantilever hit the armature of an MC.
So the tip will have much more deviation than 1 degree and gives audible flutter and tracking distorsions.
If there is predistorsion with tracing simulators( you rarely now if it is used or not,except it is Dynagroove or Royal Sound written on the LP-Cover), its getting more complex.
And a proper capacitive load of an MM is really important to the frequency response.
Often the tip could track it, but the capacity limits.
MCs can also be loaded with Caps, but with high values , EMT used for the TSD around 330 nF to flaten the resoance of the FineLine.
Resonance is one of the key reasons I use a Dual/Ortofon setup. In their days od heavy advertising, Dual claimed that all their tonearms with twin mechanical filters (which includes mine) wiil have a resonance of 2 dB 8...10 Hz, and showed this for Ortofon LM 20 cartridge. Resonance was +2.2 dB at 9 Hz, almost perfect.
This explained why I, unlike many other Ortofon cartridge owners, never had any need to complain of either slightly weak or exegerrated bass lines, rather it comes across as very well tonally balanced cartridge.
Did somebody here remember the Euphonics strain gauge PU head ?
Yes. Wasn't it a Panasonic?
Billshurv,
So by a plinth change what are you suggesting on the Technics turntable I have? Added mass or what?
Have a peek at this by Calvin MyTechnics - en - calvins-audio-pages
As you erm, have a smidge of fabrication experience you should be able to produce something really quite nice.
Strain gauge does seem to have advantages. Shame the soundsmith setup is so expensive.
I believe it was really made by a company named Euphonics. At Scientelec, we were selling rebranded ones at the time.Yes. Wasn't it a Panasonic?
There had a fantastic tracking ability and damping with high output level. The only problem was we do not provided response curve correction to compensate the RIAA flat range between the two time constants, using only the fact that they had a response proportionnal to the deplacement. So, a little lack of medium/ treble.
Now you could just use DSP.
Was this something like the Stax oder Toshiba Electret Pick-Ups, which need their own RIAA Box?
No a completely different principle, I had an electret cartridge with internal caps to make the result RIAA. They used a small piezo-electric element similar to a condenser microphone but in this case solid. A semiconductor strain gauge is a true DC position sensor based on resistance change due to flexing in one or more dimensions. That is why you see an excitation voltage/current, the output is proportional to the excitation so depending on design you can get a lot of output.
Microacoustics?
Yes that was the one, long gone now. Someone told me that in the day a typical TT with ceramic cartridge would just plow through the middle of the RIAA curve.Microacoustics?
@ Scott Wurcer
Thank you for explanation.
@SY
I think, all those special types needed their own and costly box. Not compatible.
Some of them in need of additional tonarm wires for power supply.
On the other hand MMs could be made very cheap and used the standard phono input.
I am pretty sure, that Shure sold x-times more M 75 than V 15 just due price.
And the stylus could be changed by the customer in a second or two.
@SY
I had one. Very nice cartridge. I wonder why the concept failed commercially?
Couldn't find much, here's a description I guess the circuit inside was more complicated.
Micro-Acoustics
@SY
The Micro-Acoustics was drop-in compatible with MM inputs. So it's still a mystery to me.
Robertson had a box to interface with the Panasonic strain gauge. Ditto Win. Weathers had one for their FM cartridge. You could argue that this is special and costly, and you'd be right, but it was no more costly than other good phono stages. I think in their case, it was the desire of fashion-driven audiophiles to be able to mix and match, analogous to the commercial failures of powered loudspeakers.
Another fact, here in europe those special thingies were almost unknown, be it brand or technology. We only knew abouth the Stax, but i do not remember that it was demonstratet somewhere.
High End Focus was more on the newest stylus and other gimmicks, and there had to be a good story making them popular.
I met several distributors and makers for Pick-Ups, stories, stories...
And people were keen therefor.
- Member Areas
- The Lounge
