Bybee Fraud Protection
Cryoing is a commercial process that takes time and equipment to do properly. It is NOT just dipping a component into liquid nitrogen or some such. Jack tried this method, himself, once, long ago, and said it did not do anything.
Jack goes to a commercial cryoing firm, one of which was located in Oakland, which is near where I live. This is why he would visit me more regularly some years ago, as he had to drop off or pick up stuff that was cryoed in that facility.
It amazes me that you guys do not 'google' cryoing and learn what the process entails. It has been used since WW1 for submarine hatches, for example. In WW2 it was used to extend the life of machine tools. In recent years, race car engines have been cryoed. Look it up. I know, these are ONLY mechanical changes, BUT there have been reported electrical changes too, and that is why people sometimes cryo wire, Bybee devices, and even entire circuit assemblies.
I have never cryoed anything, myself. I am just too lazy.
I don't know of any components that can take that kind of temperature on paper.
So its just an exercise taking into account if you can't afford to lose it then you don't do it. The use of an electronic freeze spray is probably better or the freezer.
Just for interest
How do you survive in the coldest place on Earth? - BBC News
But what about satellites?
M. Gregg
Satellites, space and near space are different to normal design by a long way. Components take for an age to get through the various checks and if they are not already qualified for space, forget it. Then there is the packaging, none of your normal packaging, all fancy and expensive hermetically sealed. Different world from commercial design... And I don't think they do Audio units to NASA or ESA spec. Put NASA's wiring guide up on JC Blowtorch thread recently, hundreds of pages. Of course if they did use these sort of design practices in some of the more esoteric 'high end' stuff I could understand the prices😀
OK, before I tease you fellows any more and get in trouble, let me fess up.
  • Yes, a close friend had most of his system cryo treated
  • Yes, he used a reputable facility that does cryo correctly (it was hard to find, not open to the public)
  • Yes, he had measurements done before and after
  • Yes, there was marked improvement in those measurements
  • No, it was not an audio system.
The measurements were done on a dynamometer. The system is a racing engine, a small one. For racing go-karts. There was a measured gain in horsepower (and torque IIRC) after the cryo treatment. Likely from less flex in the crankshaft, connecting rod and valves. I suspect a lot less valve float after the treatment.
The cryo facility normally treats racing aircraft engines, as seen in the Red Bull races. They test the results. But by now you are no longer interested. 😉
I can say that cryogenic treatment does change things, but I have no idea if it's any good for audio.
That's the transition I was talking about. So far, it's the only thing that cryo has had a demonstrated positive effect on.
Agreed. Despite having a really good materials guy as a lecturer never got my head around the weird stuff anything with iron in can get up to. Being as I grew up almost in the epicenter of world F1 development you would hear all sorts of stories on how engine blocks would be conditioned before use. Before they understood it properly BMW used to use blocks from the scrapyard with at least 100k miles on as the base. Ilmor used to leave blocks outside to weather and for some reason I have never understood encouraged the staff to urinate on them.
But how 'it makes a race engine more powerful' can be extrapolated to 'it makes my music sound better' I do not understand.
Bill,
Have you tried urinating on you loudspeakers?
Not so far fetched, I got a pair of Accoustats because the proud owner's dog did. He traded them in at the other stereo store in town being too embarrassed to admit to where he purchased them that they didn't work out. The other stereo store didn't want them on the sales floor, so they gave me them in trade for some pro gear they needed.
Never found any sign of moisture but one unit did have a bad high voltage diode. Had a bunch in stock so the cost of repair was a few dollars. I suspect the dog really didn't spray them as the dog would have learned about electricity.
But as far as I am concerned there may be some improvement! At least for me. 🙂
Sorry but knowing what the effect is would be critical to development I would have thought as would be measurements to check that delusion is not a contributing factor.
Sure.
In earlier informal testing I have measured significant reduction in low frequency noise...I am soon to start rigorous and repeatable measurements.
One asset with this technique is the capability of instant A/B testing on the fly, with no cable swapping, shutdown etc required.
Self delusion and delusion of others is not in the equation.
Let me hazard a guess this product would be sold to audiophiles and by bespoke audiophile outlets...
You might like to try reading my post again.
The "audiophiles and bespoke audiophile outlets" market whilst having some significance is too small to be the primary focus.
One area that is of direct interest to me, is large concert pro audio...I have treated multiple stadium systems on the sly (multicore and/or power) and the improvement is significant.
In one such test, Axl Rose stopped between songs, pointed to the FOH engineer and said "(name) is there something you're not telling me, this is the best sound I've ever had" !!!.
I also have a recording of a Devo concert and the step change in the playback sound is readily audible.
My aim is better sound for the masses, and my product idea can be readily incorporated at OEM manufacturing level, or available as a retrofittable kit to existing systems and readily affordable for typical family home AV surround systems.
Audiophile versions may be 'dressed up' a little, and intended to compliment the audiophiles 'investment' in expensive cabling etc.
Other 'audiophile' versions could be owner fittable to equipment internals and loudspeaker magnets.
My next step is indeed measurement proofs, and then maybe comes the physics explanations.
I am not interested whatsoever in airy fairy BS marketing blurb....any ad copy will be factual and straight to the point.
The underlying principle here is that very low frequency noise has far more impact on sound quality than is typically recognised.
Dan.
A new standard for audio/video enhancement.
What is it: The Bybee Enhancer is completely passive, requiring no battery of other power source. The active elements are specially formed crystals that are resistant to damage and will never lose their effectiveness. The crystals in the Bybee Enhancer are energized by any close proximity energy field. Once energized, the Bybee Enhancer creates an extended magnetic field of force effect that affects the polarity of all electrons and protons in the created magnetic field; affecting their oscillation by making them more aligned with each other. This reaction creates an effect that makes the transfer or sharing of electrons between atoms more streamline and effiecient; and air molecules less resistant. The results are a stunningly enhanced purity and energy of the video or audio signal.
How to use it: The Bybee Enhancer is typically placed over/under any kind of power cord or signal cable. It can be used on a television, computers, audio equipment; medical equipment or any other source. It is also highly effective when used over/under audio and video components such as CD or DVD players, preamplifiers and amplifiers.
The Bybee Enhancer is activated by any form of surrounding energy. For that reason, the Bybee Enhancer works best when in close contact with power cords, components, or any other source. This flexibility means that one Bybee Enhancer may be used with multiple cords and/or cables.
Placing multiple cords/cables on the Bybee Enhancer does not reduce it's effectiveness. However, the effects of the Bybee are cumulative - The more Bybee Enhancers that are implemented in a given environment the more noticeable the results will be.
Benefis Even the best high-definition television or any kind of imaging monitor will display better contrast, visual detail and color fidelity. In audio systems, bass frequencies are faster and more impactful, and high frequencies become more extended, more open and natural, without edginess. The critical midrange sounds more musical, more liquid and less "electronic." The overall presentation of imaging and soundstaging becomes both more precise and more enveloping.
In another forum I frequent, the same kind of language is used by proponents of "energy healing", such as Reiki, and makes as much sense.
