Bybee Fraud Protection
That's all very nice in a late night dorm room with bong sort of way. But can you solve the basic harmonic oscillator equation? Or a basic electron-electron scattering problem?
This thread is no different than many others, someone posts an article about one or two atoms observed doing something different at 4 degrees kelvin and in a 7 Tesla magnetic field and decide we don't understand how audio works.
Good morning SY,
Isn't that what we have you here for? 😉
+1
If the bybee doesn't work then why doesn't it work, that's what we want to know..😀
What have we got to do to make it work?
Then we can sell the working version as a side line.
The universe is made of atoms<<wrong..😀
https://www.youtube.com/watch?v=mM6OIlreneA
M. Gregg
Well that would seem to be true,
If we can't explain the Bybee..If it works that statement is correct.
But of course if it doesn't..then perhaps we do know how audio works.
M. Gregg
Bybee Quantum Signal Enhancer Operating Instructions
Here is what the instructions that came with the QSE says:
A new standard for audio/video enhancement.
What is it: The Bybee Enhancer is completely passive, requiring no battery of other power source. The active elements are specially formed crystals that are resistant to damage and will never lose their effectiveness. The crystals in the Bybee Enhancer are energized by any close proximity energy field. Once energized, the Bybee Enhancer creates an extended magnetic field of force effect that affects the polarity of all electrons and protons in the created magnetic field; affecting their oscillation by making them more aligned with each other. This reaction creates an effect that makes the transfer or sharing of electrons between atoms more streamline and effiecient; and air molecules less resistant. The results are a stunningly enhanced purity and energy of the video or audio signal.
How to use it: The Bybee Enhancer is typically placed over/under any kind of power cord or signal cable. It can be used on a television, computers, audio equipment; medical equipment or any other source. It is also highly effective when used over/under audio and video components such as CD or DVD players, preamplifiers and amplifiers.
The Bybee Enhancer is activated by any form of surrounding energy. For that reason, the Bybee Enhancer works best when in close contact with power cords, components, or any other source. This flexibility means that one Bybee Enhancer may be used with multiple cords and/or cables.
Placing multiple cords/cables on the Bybee Enhancer does not reduce it's effectiveness. However, the effects of the Bybee are cumulative - The more Bybee Enhancers that are implemented in a given environment the more noticeable the results will be.
Benefis Even the best high-definition television or any kind of imaging monitor will display better contrast, visual detail and color fidelity. In audio systems, bass frequencies are faster and more impactful, and high frequencies become more extended, more open and natural, without edginess. The critical midrange sounds more musical, more liquid and less "electronic." The overall presentation of imaging and soundstaging becomes both more precise and more enveloping.
OK, now I'm scared. If space aliens get ahold of this highly secret info, they will likely be able to reverse engineer them and use the technology against us...WE'RE DOOMED, DOOMED I TELL YA! 😱
Mike
