"Compact" VFA
Hi Peter,
I have checked your values - R3, R7 = 1.2K, R4 = 150R are fine (+/-60V rails).
6x5.6K result in VAS current = 15mA. Rather high, but acceptable with a decent heatsink.
Alert to everyone - found a typo mistake!
R7, R17, R18 must be 15K each!!!
Peter, in your case you can use 2x10K for the same value (5K), 2W is acceptable.
R8 = 1.5K, yes, slightly higher voltage gain (29.8db instead of 28.3db) - still OK.
Val
Do you mean R6, R17, R18? Bummer, I just finally received and installed the 8k2 resistors. OK, back to Mouser.
Hi Valery,
As it's not easy to each precise double layer at home i attemp to do single layer routing job for 6DJ8-All-Fet-IPS. Could take an eyes on it for advices...
Hi Valery,
Hi Marc, that's great - thank you for doing this 🙂
Looks good, just one thought - it would be useful to keep physical orientation of the MOSFETs (Q2, Q3) in such a way, that it's easy to attach a heatsink to them - in case of rather high VAS current, they will be moderately warm, so some small local heatsink is recommended.
Valery
Marc
Valery
i will take a look but think i can attach a local heatsink even in this position
Valery
Here the modification according your advice....
6DJ8 Compact VFA - CORRECTED
Hello All,
Attached are the docs with all the recently discovered mistakes corrected.
Valery
  • 08-Compact-VFA-6DJ8-BOM.zip
Compact Amplifier - Singleton CFA - "as built" refined
Compact CFA Singleton with jFET+BJT Sziklai at the input is refined for ultimate stability and reliable performance.
Attached is "as built" schematic and spectrums, measured at 50W output power @ 8 ohm dummy load.
Power supply is +/-52V DC, quiescent current is 80mA per output pair.
Layout is corrected accordingly. It's mostly TH with some SMD components, including DC servo underneath the board. PCB size: 5.5 x 3 inch.
Have fun!
Valery
