amixer scontrols
Simple mixer control 'Master',0
Simple mixer control 'Channels',0
This confirms the mixer name issue. I'll fix this for 2.0 final release 🙂 then Hardware volume control will work. For the time being, just use Software volume control.
TC
Hello TC,
I downloaded and setup and used the Moode 1.9.
It is really excellent.
Thank you very much.
I am using an old iPhone 3 to control but the iPhone 3 has a limited viewing area on the screen. I would like to seek your kind advice whether it is possible to move the "TURN OFF" facility to be slightly higher up on the screen.
I would also like to seek your advice whether the patch for the cirrus audio card is available for the version 1.9 for the raspberry pi 1.
Thank you once again.
Hello TC,
Hi, thanks for the compliment!
Minimum form factor for UI design is iPhone/iPod 5 type device, but I recognize the menu has gotten pretty long so maybe in one of the 2.x releases I'll look into making a cascade menu for the configs (Sources, MPD, Network and System) since typically they are used for setting things up initially then not used very frequently after that. Then the menu will fit on an iPhone 3.
The cirrus card is the new Wolfson card right? If the cirrus guys were able to get their drivers into 3.18.11 or .14 kernels then it should work.
Tim
A few screen shots from release 2.0 🙂
- Logarithmic volume control
- Streamlined main menu
tcmods.org
Moode on Twitter
TC
tcmods.org
Moode on Twitter
TC
Logarithmic volume is great! 🙂
Now... future developments... how do you feel about multi-room? 😱
Excellent !A few screen shots from release 2.0
Two more dacs for the database..For PiB http://hifimediy.com/DACs/diy-dacs/i2s-raspberry-pi-dac Bang for Bucks !!
ForPiB and Pi2B.....http://www.perreaux.com/products/au...ifier/audiant-80i-stereo-integrated-amplifier
if you want to try this then currently 'Sound at Home" for volumio works with Moode...😉@ Zootalaws. how do you feel about multi-room
https://volumio.org/forum/sound-home-android-app-for-multi-rooms-and-other-t21.html
https://volumio.org/soundhome-multi-room-audio-system/
https://play.google.com/store/apps/details?id=com.digx.soundhome&hl=en
and enables control of basic operations without a web-connection.
Would love to see Tims version of this too...(no pressure..🙂)
Excellent !
Two more dacs for the database..For PiB Hifimediy ES9023 I2S DAC for Raspberry Pi mod B 192Khz/24bit Bang for Bucks !!
ForPiB and Pi2B.....Audiant 80i Stereo Integrated Amplifier : Perreaux
For the Hifimediy DAC, what I2S driver did you select in System config ?
I think if MPD had the plumbing for party-mode audio distribution built-in it could be coded into a nice feature. My thought is that MPD would duplicate its local playback stream into one or more RTP/UDP unicast streams where each stream is addressed to a particular receiver client.
Receiver clients would listen for a directed stream and immediately begin playback upon receiving it, then return to a listening state when the stream ends.
If u are familiar with VLC, this type of multi-unicast, synchronized audio distribution can be configured and tested.
Maybe something like this for MPD...
SENDER
audio_output {
type “rtp-unicast"
name "My Audio Broadcast"
encoder “vorbis”
bitrate “128"
format "44100:16:2"
port "9000"
config "/etc/mpd-rtp.conf"
/etc/mpd-rtp.conf
receiver1: "host1"
receiver2: "host2"
receiverN: "hostN"
RECEIVER
audio_input {
type "rtp-unicast"
port "9000"
Tim
Hi Tim, I used the HiFiBerry DAC option.
Some screen shots of feature in 2.0 for selecting album art lookup method 🙂 The Embedded method is just a place holder for now. EAC refers to Exact Audio Copy utility.
tcmods.org
Moode on Twitter
TC
tcmods.org
Moode on Twitter
TC
Hi Tim,
Looks nice, can't wait to test the new version, thanks for the good work.
have you ever tought about adding a cd ripping funktion to your Mood Audio Player?
cheers
cheers
Also, please tell us:
1. If release 2.0 will play YouTube streams
2. Due date for release 2.0. 🙂
Hi Tim,
cheers
@rat666
I don't have the expertise to code a cd ripper. That would have to come from another project.
@StryGR
(1) My current thinking is that the Airplay receiver or UPnP renderer in Moode can be used to play any streaming service. The benefit to this approach is that the native streaming service can be used with all its nice features.
(2) Release 2.0 should be out sometime before the end of June 🙂
TC
CDparanoia is a command line ripper and is afaik also used by Vortexbox.
Morituri is a command line ripper with flac converter, tagging and accurate rip funktion.
cheers
cheers
abcde is also a cd ripper with replay gain, taggin and some other good funktions.
FrontPage - AbcdeWiki
cheers
Thanks! ABCDE looks interesting. I'll add to the to-do list.
TC
Hi Tim,
noobie here who needs your support. ;-)
I have a Pi2 powered by the 5V USB out of a Geek LPS which also powers my Geek Pulse Xfi.
I followed step 1 and 2 from the read me document (is that ok that i can´t see/choose anywhere my Dac?) but I can´t hear anything if I follow the step where i need to verify the audio playback and click on a radio station.
In addition to that I also have a problem to mount my NAS (Syno DS 213). I entered the IP and the path ( in my case /volume1/Music) but it seems to me that the folder(s) won´t be scanned (at least I don´t see anything if I go to "Browse => NAS => Flac").
Any tip from you what I should do?
btw...I have different formats on my NAS: mp3, flac (from 16-44,1 to 24-352), dsf, sacd-iso.
If I´m not mistaken all should be played but the sacd.iso, right?
Thanks in advance.
Cheers from Germany,
Markus
Thanks in advance.
Markus
Tim
Great product! I am a newb of the first order but was still able to get Moode v1.9 working with only a few headaches.
First off, I am using the Schitt Modi 2 and it works great with Moode, so might want to add that to the list.
Second, I finally got the NAS to mount when I changed NFSVERS to 4 from 3 in the setup dialogue.
Third, the Czech radio station works fine, but all the others are just white noise, LOUD white noise with no volume control.
Lastly, I cannot quite figure out how to get album art to display. I am using a directory on my NAS which contains my music in an iTunes folder.
Any suggestions are appreciated. Thanks
- PC Based
- Moode Audio Player for Raspberry Pi
